Results 1 to 10 of 21
- Feb 2010
- 71
March 16th, 2018 05:44 PM #1Background info. Timing belt and tensioner bagong palit. Pati po valve cover gasket.. sa intake po kaya galing yung kakaibang tunog or sa valves po?
https://m.youtube.com/watch?v=chsiS8eS-YU
Sent from my GT-I9300 using Tsikot Forums mobile app
- Jul 2016
- 1,178
March 16th, 2018 07:31 PM #2Parang tunog pulley bearing tunog. May 3l engine din ako dati sa hilux sr5 more than 250k kms sa odo bago ko nabenta. Ni minsan di ako binigyan sakit ulo. Timing belt lang napa litan
Sent from my vivo 1606 using Tapatalk
- Feb 2010
- 71
March 16th, 2018 07:55 PM #32nd change na po timing belt sir. Pwede rin sa me alternator pulley sir.. bago rin pala mga drive belts.
Similar dito pero medyo nasa 1k rpm
Yung ingay..
https://m.youtube.com/watch?v=6t4RudC1TkI
Sabi naman nung isang mekaniko nagseset pa yung timing belt kaya medyo masikip pa.
- Feb 2010
- 71
March 16th, 2018 08:10 PM #4Before selling it, nakapagpalit ka rin sir ng clutch set?
March 16th, 2018 08:16 PM #5
Three different abnormal noise:
1 idler pulley bearing growling/ alternator bearinggrowling
2 valve tappets clicking
3 timing belt whine (possibly too tight)
All from the video.
Why don't you invest in something like this:
https://www.google.com/search?q=mech...iw=412&bih=604
to distinguish which noise you want to address.
- Jul 2016
- 1,178
March 17th, 2018 01:33 PM #6no sir never na open clutch ko pati engine cover di rin na open, mga napalitan lang mga pang ilalim, timing belt set, hose sa air intake, cv joint. may konting pawis na between engine and transmission pero walang tagas.
na benta ko last year, palit ako ng np300, mas masarap parin gamitin hilux sr5 sa mga uphill and terrain, iba ang torque nya sa low gear walang sinabi new nissan pick up.
- 52,700
- Feb 2010
- 71
March 17th, 2018 10:36 PM #8From cold engine kanina early morning naghose down ako ng engine. Radiator pati mga drive belts. So pinaandar ko medyo matagal po ang warm up ( thermostat installed). Indi nagmanifest yun noise.
Mga 30 min medyo mahina lang. Binasa ko yung alternator belts continuous. Steady pa rin mahina noise.
Try ko tomorrow tanggal yung hose sir from valve cover to intake flange.
- Feb 2010
- 71
March 18th, 2018 02:34 PM #9Tibay din talaga sir. Yup ok sir ang drivability ng LN166 sa 4 LOW.. experiment muna ako sa source ng noise.. bisita muna tayo sa mga iba pang mechanic..
- Jul 2016
- 1,178
March 18th, 2018 05:08 PM #10Tibay talaga sir ng 3l. Hindi sya high speed sa patag pero lakas nya sa low gear. Sabi nila bullet roof daw ang 4ja1 isuzu. Para sakin 3l ang bullet proof. Ang alam ko naka base din ang design ng 2kd at 1kd sa 3l engine. Medyo nag sisi din ako bat ko binenta sr5 ko. Ano model car mo sir?
