Results 41 to 49 of 49
June 22nd, 2011 12:52 PM #41
Question mga gurus,
Timing Belt change recommendation is 70k to 80k right?
how about timing chain?
Specificaly for K20 engine CRV?
Tsikot Member Rank 5
- Nov 2003
- 3,849
June 22nd, 2011 02:14 PM #42matagal yan... maybe 200k kms pero minsan di pa kelangan. then tensioner can be replaced once it starts making noise.
- May 2013
- 2
July 7th, 2014 03:31 PM #43Inputs po sana mga idol. 2nd hand Toyota Innova owner here.
1.) Talaga bang mas maninipis na ang bagong labas ngayon na timing belt compare before? kapapalit ko lang kasi, pero prang magkasing kapal lang ung timing belt na luma compare sa bago, to think na faded na ung prints nung luma.
2.) And also, anung mas ok advisable in terms sa higpit ng timing belt, ung iba kasi loose ung iba mejo mahigpit. TIA
August 20th, 2014 12:32 AM #44
Hello mga ka-tsikot, we recently bought honda civic 2004 AT and suggestion samin ng mechanic is to replace the timing belt since wala kami history regarding sa maintenance ng previous owner, ok na po ba yung quotation na 8.1k lahat lahat na including labor?
- Aug 2008
- 405
August 20th, 2014 12:44 AM #45^^ I think that is too much if it is only for the timing belt replacement.
- Jun 2004
- 1,311
August 20th, 2014 01:35 AM #46
August 20th, 2014 06:59 AM #47
88k plus na po mileage nung car, and advise samin to be safe we should replace the timing belt etc pra may sarili na kaming record, eto po ung quote samin
2,250 timing belt orig
1,900 tensioner bearing
1,400 water pump
450 crankshaft oil seal
350 camshaft oil seal
1,800 labor
Posted via Tsikot Mobile App
August 20th, 2014 07:15 AM #48
Guys, 'yung timing belt ko kasi nag-iingay na. Then nung nagpa change oil ako sabi ng mekaniko hindi raw sila nagpapalit pero sisikapan lang naman daw 'yung timing belt ko. Tama lang ba ginawa, pagkakaalala ko kasi kapapalit ko lang ng mga belt tapos almost a year na tengga kotse ko, so hindi nagamit para malaspag 'yung mga belt.
August 20th, 2014 07:20 AM #49
Sir rickymartin, magkano po nagastos mo dati all in all sa timing belt replacement?
Yes Yes squeaking sound is heard when shifting only
