Results 1 to 8 of 8
- Feb 2008
- 82
August 20th, 2014 11:34 AM #1Help me mga masters. My 2008 Toyota Avanza J seems to have an idling problem. The RPM goes up and down when the A/C is on and there is a clicking relay sound. This only happens when on full stop with A/C on. Youtube video below:
August 20th, 2014 12:23 PM #2
parang nangyayari yan pag nag eengage yung compressor ah...
siguro best thing you can do is to have your compressor and its related electricals checked.
August 20th, 2014 02:01 PM #4
Did you have AC work done? Your AC circuit is experiencing hi-pressure. Kaya erratic on-off yung compressor.
August 20th, 2014 03:06 PM #5
Sir pacheck mo yun sensor sa throttle yun apat yun wire yan kasi ang nag control sa idling
- Feb 2008
- 82
August 21st, 2014 07:33 PM #6Salamat mga paps. Any more inputs? By the way, nawala symptoms kanina. So mukhang intermittent.
- 52,813
Tsikot Member Rank 4
- 2,718
August 22nd, 2014 02:37 PM #8pa-check na rin yung pressure sensor ng aircon/freon ... madali lang naman i-test ito ng aircon mechanic
i wonder, are the usual published suspension adjustment specifications supposed to be adjusted...
Wheel Alignment
