Results 1 to 10 of 49
- Jan 2011
- 262
March 31st, 2011 12:24 PM #1Good morning fellow Tsikoteers!
I just want to ask what are the symptoms if you should already change your timing belt? Others said that it's based on the mileage of the car (70T to 80T kms) but the thing is, I'm not sure whether my odometer is tampered or not.
So far I don't hear any noises and the acceleration is still smooth. I just want to make sure that everything's ok to prevent future damages.
Hope you can help me with this..
March 31st, 2011 01:35 PM #2
Wala sintomas neto except visual inspection ng belt at odo readings.
Most deadly symptom of a badly needed t-belt replacement? engine stopped running. Ayun, putol na pala. Pati piston at valve nadale. Overhaul tuloy..back read ka ng threads pa dito marami na nagdiscuss neto.
I assume hindi ikaw ang first owner ng pipip mo kaya if in doubt replace agad. wag mo na antayin pa maputol.
March 31st, 2011 02:58 PM #3
try refraining from using the mileage as a basis of timing belt replacement. manila is considered extreme extreme or major major driving conditions with all the traffic jams, stop and go, start and turn off duty cycles. if the car is stuck in traffic, the odometer does not count the mileage but the engine's timing belt is incurring hours of use. when you replace the timing belt, it is customary to replace the idler, tensioner pulley, camshaft seal/s, oil pump seal (if applicable) if it has overhead cams, front crankshaft seal and as a recommendation, replace the water pump too since the front of the engine is already open and it requires less time to do all these than piece by piece. these are called MAW (might as well) parts.
- Jan 2011
- 262
March 31st, 2011 03:31 PM #4Thanks for the inputs!
If I would have it checked, where do you think is better? CASA or a reputable shop like Speedyfix?
My dad said that it would be better if sa CASA na lang daw? Is this true?
March 31st, 2011 04:23 PM #5
not all techs at the dealership shops are that good. sometimes, if the tech or employee is disgruntled with the management, they sabotage the customer's car when they know they are getting the pink slip. on the other hand, independent shops might not have the tools, training, and correct repair procedures. just check around for customer feedback of the shops.
March 31st, 2011 04:49 PM #6
True na dapat 'wag na hinayin yung 100K odometer reading bago magpalit. Kaya nga common sinasabi sa timing belts ay mga 80K-90K palitan na agad para may safe clearance pa talaga.
For the MAW tama rin si sir jick. Sabay na dapat yan para isang gawaan at mas malaki chance na 80K-90K ka na uli magpapalit ng mga yan.Fasten your seatbelt! Or else... Driven To Thrill!
- Jan 2011
- 262
March 31st, 2011 05:12 PM #7
April 1st, 2011 12:12 PM #8
April 1st, 2011 01:22 PM #9
after 72,000kms ako nalagutan ng oem timing belt, top overhaul ang ginawa ng diamond motors. medyo napabayaan ko kasi ito before, ngayon hindi na. palit na every P70,000kms.
- Jul 2005
- 122
April 1st, 2011 05:13 PM #10
watched on youtube yung drain-and-fill. parang madali lang. weird lang yung overflow hole, coz it's...
All new Mitsubishi Expander MPV!
