Page 6 of 9 FirstFirst ... 23456789 LastLast
Results 101 to 120 of 174
    May 2019
    #101
    Mas mura cath. I-Lala move si uls mismo papunta sa inyo. [emoji23]
    Hahahahahaha [emoji23] panalo ito!!
    Sagot ko na lalamove..
    Magkatotoo lang.. [emoji1308]
    [emoji1787][emoji1787][emoji1787]
    EDIT: ipa-package din ba si Sir Uls.. Tapos may ribbon yung kahon.. Hahahahahaha [emoji23]
    Feb 2009
    #102
    the more these clowns and "mechanics" mess with the car, the more it gets messed up. just stick with the routine preventive maintenance
    #103
    Quote Originally Posted by Miles_on View Post
    CVT fluid is "lifetime" daw, but that's bunk.]
    what they probably mean is,
    "when the CVT fails, its lifetime is over."
    then, you don't need to do fluid change. you need to replace the CVT!
    tsaka naka bubble wrap
    hehe
    May 2019
    #105
    hehe
    May sticker na
    "Handle with Care"..
    [emoji1787][emoji1787][emoji1787][emoji1787][emoji1787]
    Feb 2009
    #106
    joking aside,
    cathy, you can do the coil replacement yourself. all it takes is 8 5mm bolts with 10mm heads, four connectors to disconnect and reconnect. will gladly provide assistance to you
    oo cathy madali lang yan
    isa diyan di gumagana
    Baka maging diesel yan kung si Cathy gagawa.
    #109
    Yun lang hahaha
    I had an anxiety attack this morning. I couldn't breathe Feeling ko talaga lemon car ko and I need to dispose of this soon pero hindi talaga ako bibilhan ng bago e jobless ako [emoji24]
    Anyway, thanks to the Tsikot community kasi yung 40k PMS ko na P18k was cut in half! Kung madadala ko lang car ko sa QC baka less than P10k lang magastos ko for the coil ignition and valve cover
    #110
    joking aside,
    Thank you so much, I can't afford you though I thought you are in the US or somewhere else?
    I feel so bad having to pay P27k for that but casa is the closest and most convenient place for me kasi. One thing I hate the most pala is paying for something I know I can get cheaper. I am so OC na I'd go to different groceries para I can buy where it is cheapest (I take into account din na I don't pay for parking or sabay ko sa ibang lakas) Tapos now I have to pay P7k for labor when I can do it almost for free (from ULS) or you? hahaha
    BTW with my older cars my Dad taught me how change oil myself, I know how to change the spark plugs but with newer cars (since my 10th gen) I absolutely do NOT open the hood anymore.
    Sobrang taga nga yung labor but the parts is okay kasi may factory warranty yan. Anyway, we pay for convenience talaga.
    then this
    easy peasy
    kasing dali changing spark plugs
    tapos gawa ka ng sariling resibo para may ma-file ka
    haha
    #114
    then this
    easy peasy
    If it's just like spark plug kaya ko pero I'm not brave enough haha
    Btw bakit pala hindi pinalitan spark plug ko sa 40k pms. Sa old car ko every pms palit ako spark plug
    di pa
    too early to replace platinum spark plugs
    lalo too early kung iridium
    #116
    di pa
    Oh di ko kasi maalala na when they changed my spark plugs, must have been a long long time ago
    Sabi friend ko premature din yun valve cover leak ko. Lemon ata talaga car ko [emoji24]
    #117
    okay na pala parts? Around P2k each lang kasi coil ignition sa lazada (may P500 pa nga), e sa casa P4k each Though not sure kung Genuine Toyota
    baka wala leak pero gusto lang nila kumita
    Sep 2021
    #119
    Yun lang hahaha
    Lemon?
    Simple wear and tear lang yan. Think of it as just a tire being replaced or a tailight bulb going out...
    Every car make & model has its particular quirks naman, with some more prone to certain issues than others. Baka in the case of the Altis, its this #2 ignition coil.
    At least on record na yan here, dagdag sa collective knowledge base here in Tsikot forums.
    Feb 2009
    #120
    at the local toyota dealership shop, they charge $155 per hour
    for replacing the valve cover gasket, that'll include replacement of the ignition coils, i normally charge 1 1/2 hours * $85 an hour fully documented with 0ne year warranty. if i was there, i offered to do it for you for free. where i'm at my rate per hour is lower than even the shops in both usn and usaf shops.
Sudden Rough Idling/Car Shaking
