Results 71 to 80 of 174
March 15th, 2023 05:32 PM #71
I'm wondering nga parang I don't see CVT sa 40k pms
Thanks. Sabi ko bakit mahal, my SA said kasi 40k replace all fluids daw e bakit parang wala naman ako masyado nakikitang fluids there except for sa brakes. I don't see the CVT fluid
March 15th, 2023 05:33 PM #72
does one really need "toyota genuine engine room cleaner" and "toyota genuine engine room coat"?
juice ko mga casa talaga
March 15th, 2023 05:41 PM #73
^hahaha
Yung engine decarbonizing hindi pala yun necessary? Yun na yun sabi dito i floor lang yun gas sa highway? Lol. That's P2k din kasi
March 15th, 2023 05:47 PM #75
there are nine typical fluids in a regular car. some of them are not applicable to all cars.
1.motor oil/engine oil
2. automatic transmission oil
3.manual transmission oil/differential oil/manual steering gear(parallelogram, haltenberger linkage, cross steer systems)
4. brake fluid-DOT3,4,5,5.1
5. windshield washer fluid
6.antifreeze/coolant
7.battery electrolyte
8. fuel
9.refrigerant
any applicable fluid in your car has a projected service life.
stick with the car's owner's manual for fluid maintenanceLast edited by jick.cejoco; March 15th, 2023 at 05:49 PM.
- Jan 2007
- 2,224
March 15th, 2023 05:52 PM #76Decarbonizing IMO is useful sa GDI engines and diesels with dirty EGR. For old-school port-injected gasoline there's no need really.
Early coil packs were a common point of failure talaga. I remember my friend would carry a full set of coils with him because his car (an Evo VII) would have one go bad every so often. Nakakatawa din we had a funrun to Antonio's in Tagaytay, and when we got there the first thing we see him do is pop the hood and start checking the coilpacks
March 15th, 2023 05:52 PM #77
March 15th, 2023 05:56 PM #78
Cathy ... have a flatbed tow truck (why are they still called TOW trucks?) bring your car to ULS or whoever is willing to help you ... it's going to cost much, much cheaper and the work done will be much, much better ... that 7 hour labor charge alone is worth more than the towing service ...
PULL THE COROLLA out of casa ...
March 15th, 2023 05:57 PM #79
Cath, mas konti pa mileage ng 2015 explorer ko sayo, low 30k+ pa lang. But I'm using it more often now dahil ganun pa rin maintenance cost whether gamitin or hinde. Pinagawa ko na 100th kms PMS na. Replace all fluids pati drive belt.
- 52,697
March 15th, 2023 06:01 PM #80"dead cylinder" simply means,
that cylinder is not contributing to the power generation of the engine.
a common fault is, the fuel mixture isn't igniting, i.e., something wrong with the hi tension, or there's not enough fuel...
it does not translate to major engine fix.
in my last casa pms,
the SA was perusing his monitor screen for my data...
"basic lang sir, tama?"
it appears, my "kuripot ang costumer na 'to. oil and filter only, nothing more" has been input-ed in their database.Last edited by dr. d; March 15th, 2023 at 06:05 PM.
Neither's mine. 3 yrs old and no issues whatsoever. Initial 2 PMS lang sa casa, the rest is OC...
Suzuki JIMNY [merged threads]
