Quote Originally Posted by olidotcom View Post
based on my experience it did my fuel consumption before was between 8 to 9km/li then after changing to 5W30 it became 9 to 10 km/li.. sometimes it went around 11... i think it was because it was less traffic that week.. that caused the 11km/li
felt my hp somewhat increased because sometimes i feel the need of having a 'heavy feet' if you know what i mean... and comparing before and after change oils... i tend to shift faster because i was already hitting my desired RPM prior to shifting.. so from that my engine was taking easier to transfer power to the wheels then to the road thus a faster speed.
well, thats for my experience sa ride ko... but of course, iba din ang magiging experience for your engine.. iba-iba din ang mga reaction nila.. parang may sariling buhay. hehehe.....
thank you sir for sharing. i think i'll go for 5W now.
Quote Originally Posted by speedyfix
drin21, if you manual suggests 75w90 you should use the RP max gear. it'll meet the requirements of your transmission. you can use either 5w30 or 10w30. i wouldn't expect any major milage increase if you switch to 5w30 though. yes, castrol, mobil and most other oils are group III. RP, redline, some motuls are group IV. some motuls are group V.
thanks sir for clearing those things up. will drop by your shop to get myself some RP.
