additional questions sir..
is it true na grade III lang ang Castrol oils? RP and Castrol kasi pinagpipilian ko for my next oil change. my car's warranty is over so pwede na ako outside the casa.
is it ok to use 5W-30 instead of 10W-30 on my 2007 Aveo? will it increase the engine performance (even for a small margin only) because it is thinner? it has been using 10W-30 eversince kasi. i am worried about 5W because the manual says use 10W on hot climate.
do i need to flush the engine since i have been using oil from the casa? or ok lang na hindi na magflush pag nagswitch sa RP?
can i use Max Gear for the manual tranny fluid?
thanks in advance sir.
