Page 13 of 52 FirstFirst ... 39101112131415161723 ... LastLast
Results 241 to 260 of 1023
    Nov 2003
    #241
    mau2485, yeah 10w40 should be fine for your engine. our plugs are 100/pc for regular ngk's.
    jeff, thanks for pointing out the dealers there!
    Tatchest, i think it might be better if you stick with the slightly thicker 10w40 viscosity
    #242
    Quote Originally Posted by speedyfix View Post
    Speedyfix,
    For Nissan Navara, ano recommended mo? 4x4 AT siya.?
    Bili nalang sana ako ng oil then change dito sa Nissan Ilocos nalang. TIA
    Nov 2003
    #243
    for most diesels we use our 15w40 oil.
    Feb 2009
    #244
    Sir Speedyfix,
    Magkano po yung per liter ng 5w30 and 10w40 ng royal purple nyo?
    Magkano rin po yung 1 gallon?
    Thanks!
    Nov 2003
    #245
    the 5w30 and 10w40 both retail for 550/quart. wala sya gallon. the only viscosity that comes in gallons is the 15w40 and that is 2200/gallon.
    Feb 2009
    #246
    Awww mas mura yung sa inyo aus! plan ko kasi mag RP oil kasi sobrang lakas ng car ko sa gas 5km/l. Gusto ko sana mag 5w30 hoping na makatipid sa gas. I am planing to have a tune-up this comming september or october. My car manual said that the recommended oil is 5w30 but iniisip ko kung magkakaproblem ako sa oil leaks sayang naman kung matatapon lang yung RP oil mahal pa naman.
    Nov 2003
    #247
    if it leaks then replace the gasket or oil seal siguro and it'll be ok na after
    #248
    Migs, parang may nakita na ako na 5w-30 na gallon sa tyre rack ortigas.
    correct me if im wrong.
    Migs, may mercon atf ba na RP? yung kasi nakalagay sa e150. thanks.
    Feb 2009
    #249
    Quote Originally Posted by s_quilicot View Post
    Di kaya Liqui Moly yung nakita mo sir? parehas kasing purple eh
    #250
    Quote Originally Posted by mau2485 View Post
    Royal Purple yun. I swear.
    Nov 2003
    #251
    nope, walang gallon dun that was the 15w40
    max atf meets the mercon requirement
    Dec 2008
    #252
    sir speedyfix magkano ang full synth for crdi mine is montero may kamahalan ang mitsu synth eh and also is there any particular store selling RP here in Davao tia
    Nov 2003
    #253
    same din, 550/quart pero no dealers yet in davao
    Apr 2008
    #254
    I didn't know RP is the official oil of G.I. Joe.
    I saw drums and liter bottles of Royal Purple oil in the background.
    Galing!
    Yo Joe!
    #255
    Quote Originally Posted by uvwx776 View Post
    The world rushes on over the strings of the lingering heart making    the music of sadness.
    WTF! spam bot ba to?
    May 2008
    #256
    IMm29, glad you think so
    wrcastro_ph, parang nadaanan na namin lahat nun ah. hehe! RP has the most comprehensive lineup of viscosities to choose from which is why it's pretty impressive.
    simplicity, you're best off using the 10w40. yup we have it and pwede yan viscosity sa promo.
    snowbound, RP syn oil is 440/liter, RP XPR racing oil 850/lit, syn ATF 650/lit, syn gear oils 700/lit.
    mbeige, yup meron. look for the 15w40 viscosity oil. complete API certification for diesel engines
    Sir,
    Do the prices still hold? How many liters for a turbocharged diesel engine?
    Regards!
    #257
    Quote Originally Posted by Blaster87 View Post
    Sir,
    Regards!
    sir AFAIK nag increase na sila ng price. 550 per quart of oil and 700 na ata per liter ng atf.
    pa correct nalang po kung mali.
    Nov 2003
    #258
    yeah they sponsored g.i. joe and also iron man before.
    tama, new prices are 550/quart for engine oil. most diesels require between 7-8 quarts.
    #259
    I have 10w30 spare. Can I mix it with 10w40? 1 quart 10w30 and 2 quarts 10w40. Pronto only have 10w40 available and its impossible for me to go to Shaw. Pwede ba eto sa Picanto with 60k odo? May shop ba na malapit sa Laguna Binan that sells RP?
    Nov 2003
    #260
    yes you can mix any of the multigrade viscosities. it'll be no problem. ok lang yun on the picanto
Royal Purple Oil
