Results 1 to 20 of 3899
    Bro alam ko Nippon Micro at JS Asakashi ang mga recommended ni Japan ABC, wala pa bang nakasubok dito sa Tsikot?
    Cant' find reliable JSA shop aside from online. Baka may alam ka supplier na may store? The Sakura brand from Indonesia is improving, pwede na itapat sa Donaldson Indonesia.
    Aug 2017
    Who sells Nippon Micro oil filters around the Metro? Any recommendations?
    Si crazy boy ang supplier ng JSA at ang Nippon Micro ay sa Visayas at Mindanao available and the distributor is located in Cebu according to the post of Japan ABC.
    My Innova 2008 model has a gas engine with over 130,000km ODO. Read somewhere about Oil Catch Cans... My questions are: Should I install one (readily available is MANN Provent 200) considering na gas yung engine ko? Marami ba dito nag-install ng ganito? Is it difficult to maintain? Complicated ba ang maintenance to a noob just like me who wants to learn and try it out? Can the maintenance be done during the 5,000km PMS?
    Quote Originally Posted by attyallanlatras View Post
    OCC is not really needed for a gas fed engine. More ideal for diesel vehicles.
    Sent from my SM-G965F using Tapatalk
    Thanks.... My Fortuner 2016 A/T has a 2.4 Diesel engine. Warranty would expire May this year. Would the installation of an OCC be difficult? How about maintaining it, could it be done during the PMS or should it be earlier? Is it difficult to maintain an OCC?
    It depends upon the OCC that you will install. Some are easy yo maintain others are not. But most aftermarket OCC have easy drain plugs. Once a year lang ang drain ng oil niyan.
    Just make sure na yung sukat ng intake at nung sa breathet sa valve cover mo ay pareho. Just do some research on the net about OCC to get a better understanding.
    For gasoline, crankcase ventilation is controlled by the PCV valve. You just need to maintain that PCV valve to avoid buildup of gunk and unecessary pressure.
    For diesels, crankcase is open directly vented in the air-intake manifold that is why negative pressure amplifies the oil-mist being ingested back to the intake, hence the need to install OCC.
Remote bypass oil filtration
