Results 2,521 to 2,530 of 3899
- May 2012
- 372
July 29th, 2012 12:08 AM #2522
July 29th, 2012 12:38 AM #2523
July 29th, 2012 12:14 PM #2524
Guys bmay Baldwin oil filter ba for Vios 08? And may mabibilhan na shop sa Banawe? If meron, where? Thanks. I've heard na 15w40 Caltex Delo Gold daw magandang "cleaning" oil? Planning to change kasi from Idemitsu 5w30 to this eh. Sabi sakin wag na raw mag engine flush kasi makakasama pa raw sa makina. TIA po. Sorry daming tanong.
July 29th, 2012 01:12 PM #2525
July 29th, 2012 01:52 PM #2526
July 29th, 2012 08:28 PM #2527
if you are going to use Caltex Delo I suggest you use Caltex Delo Gold Ultra 15w40 instead of Delo Gold. Gold Ultra has the "safe" amount of Zinc, 1200 PPM. Anything higher than 1200 PPM is not safe for the Catalytic Converter. Mas mura nga lang ng onti yung Gold (215 per liter, i just checked yesterday at a local Caltex shop here in Angeles City. Delo Gold Ultra is at 230 per liter.
Delo Gold - Zinc * 1500 PPM; API Rating CH-4
Delo Gold Ultra - Zinc * 1200 PPM; API Rating CI-4 ( Safe for Cat Con)
July 29th, 2012 08:35 PM #2528
chiks, problem kasi with idemitsu eco, weight 30 is not suitable for our weather. im currently using Zic brand oil. it was posted here before na ok itong brand and affordable siya. dvldoc also recommended this brand. its the biggest group3 (semi-syn) oil manufacturer around the world.
bale Zic + baldwin combo gamit ko sa fleet namin. though 5k km OCI parin ako sa mga toyota namin.
July 29th, 2012 08:49 PM #2529
mga gurus papost naman ulit ng efficiency rating (nominal rating) ng:
1. BT223
2. LF3335
3. Valvoline V0-106
namention na sakin kanina ni doc nakalimutan kong isulat.
thanks in advance
July 29th, 2012 09:37 PM #2530
The bt223 is 98% * 25 microns its nominal rating is 12 microns * 50% so it means on a single pass it will filter out 50% of particles that are down to 12 microns, The fleetguard has the same absoulute rating but they do not publish the nominal rating.
Valvoline v106 is 98% * 20 microns
Personally, I'd sooner keep a donut spare tire in the trunk than use a tire sealant. Trust me. I...
Liquid tire sealant
