Page 157 of 195 FirstFirst ... 57107147153154155156157158159160161167 ... LastLast
Results 3,121 to 3,140 of 3899
    #3121
    chiks, for Honda, ang alam ko B1402 dapat. thats longer than stock na yata.
    as for the Yota, stick if BT223 na. perfect size na siya e. and marami naman yang stock
    #3122
    Gusto ko sana ng longer version ng filter hehe mas matagal ba ng konti ang OCI kapag longer filter? Particularly for the Civic sana kasi luma na yun kaya gusto ko lagyan ng Baldwin.
    Jun 2005
    #3123
    I think B166 will fit the civic.Will wait kay doc and bayen anong pwede for civic na mas malaking filter.
    Jan 2012
    #3124
    Quote Originally Posted by vanich View Post
    for the PH15 or PH16 engine I think Masyado malaki outer diameter ng B166. Kung B16, D16 engine yun, kasya pa dun.
    Jan 2012
    #3125
    Ayun perfect may picture.
    Given than filter positioning, you can use any m20X1.5 thread oil filter as long as the outer diameter does not exceed 3.05 inches.
    sa length, looking at the picture, you can easily fit a 4 to 5 inches filter here.
    Given that here are your choices:
    B227
    LF3691
    LF3624
    LF3960
    LF3649
    LF716
    B199
    B179
    PH2808 - luberfiner
    PH2903 - luberfiner
    LF3403
    B161-S - GUSTO ko neto hirap maghanap. hehehe perfect max size to for my GE.
    B1402
    B1431
    B1400
    madami pang ibang pwede pero as of now those are the ones on top of my head. B179 lang meron ako now. the rest of the ones listed above i'll have them soon...
    Re: PSID, usually for after market filters mas mataas yung PSID setting nya over stock ones. eto lang yung setting na the filter will go on bypass once barado na sya. its very unlikely though na mababara mo yung baldwin or fleetguard or any fleet service filter as it has 4 times dirt holding capacity than oem but if you do, then at certain PSID depende dun sa setting nung nabili mo it will go on bypass... to prevent the engine from oil starvation.
    1 a 14, 20 or even 30 PSID setting is not so uncommon and perfectly safe to use with our engines.
    For the VIOS idol pwede ka mag B178. see picture below:
    Malayo pa yung filter na yan to the ground so kahit lowered ka pa hindi sasayad yung filter sa ground.
    other pictures of filter mountings on different rides are posted here:
    https://www.facebook.com/FiltersDepot
    browse na lang kayo mga kapatid. kung may gusto kayo add, go lang. am documenting pictures of filter mounting for easier reference kapag may mga nagtatanong
    #3126
    Quote Originally Posted by bayen View Post
    B227
    LF3691
    LF3624
    LF3960
    LF3649
    LF716
    B199
    B179
    PH2808 - luberfiner
    PH2903 - luberfiner
    LF3403
    B1402
    B1431
    B1400
    B1402 wala ka pa idol? Hehe. Thanks sa input!
    #3127
    sa volmax madaming B1402 chiks. 350 yata price
    #3128
    Thanks sir.
    *bayen
    Saw your FB page na sir. Pinost mo na pala dun photo ko.
    #3129
    Thanks sir.
    *bayen
    Saw your FB page na sir. Pinost mo na pala dun photo ko nung EK. Sayang gusto ko kasi talaga ng longer filter pero will settle for B1402 muna siguro.
    Dec 2007
    #3130
    Looks like I got Bayen fully addicted to filters lol.
    Jan 2012
    #3131
    Nice to hear from you Doc. When you heading back in the PH?
    BT223 installed on a Camry.
    * Chics
    Yup. Posted it in my FB page. Hope okay lang sayo brother.
    B199 may padating ako. sabihan kita kapag nandyan na.
    #3132
    * Chics
    No prob bro. Credits na lang siguro.
    Tumawag rin ako kay Gigatrade, wala rin silang B199. Itim na langis nung EK namin. Lapot pa, 20W50 kasi.
    #3133
    I agree. Credits nalang siguro to acknowledge the owner of the photos.
    Chiks, sayang kakagaling ko lang ng volmax last sat hehe dapat pala itinext muna kita kung may papasabay ka ba.
    #3134
    Hehe next time siguro. Actually galing si erpat sa Divisoria area kanina kaso sarado raw yung mga shops, although sinabi ko na sa kanya na baka sarado nga kasi linggo.
    Jan 2012
    #3135
    Will do idol. thanks again.
    Malapot na ba idol? bigat nyan 20w50, hindi pa affected fuel efficiency mo?
    #3136
    Actually di namin nasusukat FC, pero hindi naman lumalagok ng gas or sobrang bilis bumaba ng fuel gauge. Planning to change it to Caltex DGU, sayang kasi yung natira kong 1.5 liters na DGU.
    Jan 2013
    #3137
    Doc what do you think of this?
    37Degree Filters - 37Degree Filters
    Is it worth the money?
    Dec 2007
    #3138
    Totally not worth it, You could do a 5 micron bypass set up for way less than that price. It's only a 24 micron filter. Who wants to wash out a re-usable filter? With a recommended oil change interval of 3000 miles. Pure crap.
    Jan 2013
    #3139
    Doc do you recommend buying oil lubricants from Petron? Their fully synthetic Rev-x All terrain is less than 400 pesos per liter with the following specs
    REV-X ALL-TERRAIN 5w-40
    REV-X ALL-TERRAIN is a synthetic, ultra-high, multi-grade, heavy-duty engine oil meeting the highest level of American and European heavy-duty diesel specification.
    PROPERTIES
    • Meets demanding needs of modern day low emission engines • Has superior soot control that reduces ring and liner wear and provides veering corrosion protection • Has high resistance to oil thickening and gum formation • Has exceptional anti-oxidant performance that reduces oil degradation • Has outstanding piston cleanliness • Allows for extended oil drain interval due to enhanced dispersancy • Reduces oil consumption that leads to less top-ups • Improves engine startability and idling characteristics
    APPLICATION: Turbocharged or supercharged high performance diesel engines operating under both low speed-high load and high speed-high loads condition
    AVAILABLE PACKAGES
    • 200-liter drum
    • 18-liter pail
    • 6 x 1 liter in carton
    TYPICAL CHARACTERISTICS
    Specific Gravity at 15.6 ēC 0.8609
    Flash Point, COC, ēC 206
    Color, ASTM <3.5
    Viscosity at 40 ēC, cSt 74.30
    Viscosity at 100 ēC, cSt 12.06
    Viscosity Index 159
    TBN, mg KOH/g 16
    info taken from this site Promethium Marketing Company - Products & Services - Automotive Lubricants
    Dec 2007
    #3140
    Dang that's good oil Viscosity index of 159 and TBN of 16, That bad boy has plenty of ZDDP in it. Price wise ahhhhhh kinda pricey but not to bad. But you will get extended oil change intervals out of it. Easily a 8000kl interval with a good filter.
    * Bayen clean your inbox man your over your storage limit. I will be back next month.
Remote bypass oil filtration
