I think B166 will fit the civic.Will wait kay doc and bayen anong pwede for civic na mas malaking filter.
Ayun perfect may picture.
Given than filter positioning, you can use any m20X1.5 thread oil filter as long as the outer diameter does not exceed 3.05 inches.
sa length, looking at the picture, you can easily fit a 4 to 5 inches filter here.
Given that here are your choices:
B227
LF3691
LF3624
LF3960
LF3649
LF716
B199
B179
PH2808 - luberfiner
PH2903 - luberfiner
LF3403
B161-S - GUSTO ko neto hirap maghanap. hehehe perfect max size to for my GE.
B1402
B1431
B1400
madami pang ibang pwede pero as of now those are the ones on top of my head. B179 lang meron ako now. the rest of the ones listed above i'll have them soon...
Re: PSID, usually for after market filters mas mataas yung PSID setting nya over stock ones. eto lang yung setting na the filter will go on bypass once barado na sya. its very unlikely though na mababara mo yung baldwin or fleetguard or any fleet service filter as it has 4 times dirt holding capacity than oem but if you do, then at certain PSID depende dun sa setting nung nabili mo it will go on bypass... to prevent the engine from oil starvation.
1 a 14, 20 or even 30 PSID setting is not so uncommon and perfectly safe to use with our engines.
For the VIOS idol pwede ka mag B178. see picture below:
Malayo pa yung filter na yan to the ground so kahit lowered ka pa hindi sasayad yung filter sa ground.
other pictures of filter mountings on different rides are posted here:
https://www.facebook.com/FiltersDepot
browse na lang kayo mga kapatid. kung may gusto kayo add, go lang. am documenting pictures of filter mounting for easier reference kapag may mga nagtatanong
