Page 253 of 390 FirstFirst ... 153203243249250251252253254255256257263303353 ... LastLast
Results 2,521 to 2,530 of 3899
    May 2012
    #2521
    im about to try this baldwin oilfilter on my next oil change.
    Feb 2012
    #2522
    Quote Originally Posted by bayen View Post
    natapos ko din after a week.
    ang haba na ng thread na to. Worth reading. dami ko natutunan.
    Anyone here knows whats the FG or Baldwin part number for Fuel Filter for Honda Jazz 2010?
    Thanks.
    ako isang buwan na yata, nangangalahati pa lamang. hehe. pero tama ka, dami ka matutunan dito. if only easily available yung mga oil filters na highly recommended dito.
    Jan 2012
    #2523
    Quote Originally Posted by gearhead000 View Post
    binebenta na lahat ni dvldoc yung stash nya. madali syang stock ng baldwin at fleetguard and other quality filters. just pm him and am sure he has what filter you need for your ride.
    #2524
    Guys bmay Baldwin oil filter ba for Vios 08? And may mabibilhan na shop sa Banawe? If meron, where? Thanks. I've heard na 15w40 Caltex Delo Gold daw magandang "cleaning" oil? Planning to change kasi from Idemitsu 5w30 to this eh. Sabi sakin wag na raw mag engine flush kasi makakasama pa raw sa makina. TIA po. Sorry daming tanong.
    #2525
    Chiks, baldwin bt223 for toyota. Yan gamit ko sa innova and vios gen2 namin. As for oil, dont use weight 30 oil. I used the idemitsu eco oil before sa vios. Ang pangit ng response.
    #2526
    Thanks. Yup Idemitsu Eco rin gamit ko di ko masyado napapansin difference hehe. Okay na siguro yung 15w40 na Delo Gold, ano? No need to flush na rin ba? Kasi from FS oil to ordinary oil.
    Jan 2012
    #2527
    if you are going to use Caltex Delo I suggest you use Caltex Delo Gold Ultra 15w40 instead of Delo Gold. Gold Ultra has the "safe" amount of Zinc, 1200 PPM. Anything higher than 1200 PPM is not safe for the Catalytic Converter. Mas mura nga lang ng onti yung Gold (215 per liter, i just checked yesterday at a local Caltex shop here in Angeles City. Delo Gold Ultra is at 230 per liter.
    Delo Gold - Zinc * 1500 PPM; API Rating CH-4
    Delo Gold Ultra - Zinc * 1200 PPM; API Rating CI-4 ( Safe for Cat Con)
    #2528
    chiks, problem kasi with idemitsu eco, weight 30 is not suitable for our weather. im currently using Zic brand oil. it was posted here before na ok itong brand and affordable siya. dvldoc also recommended this brand. its the biggest group3 (semi-syn) oil manufacturer around the world.
    bale Zic + baldwin combo gamit ko sa fleet namin. though 5k km OCI parin ako sa mga toyota namin.
    Jan 2012
    #2529
    mga gurus papost naman ulit ng efficiency rating (nominal rating) ng:
    1. BT223
    2. LF3335
    3. Valvoline V0-106
    namention na sakin kanina ni doc nakalimutan kong isulat.
    thanks in advance
    Dec 2007
    #2530
    The bt223 is 98% * 25 microns its nominal rating is 12 microns * 50% so it means on a single pass it will filter out 50% of particles that are down to 12 microns, The fleetguard has the same absoulute rating but they do not publish the nominal rating.
    Valvoline v106 is 98% * 20 microns
Remote bypass oil filtration
