Page 163 of 390 FirstFirst ... 63113153159160161162163164165166167173213263 ... LastLast
Results 1,621 to 1,630 of 3899
    #1621
    I did find this online. Looks to be close to the 51809 size though I can't tell exactly. Note it says for 10000k oil changes. Its a direct cross for the BD7028, which is still about 2 inches shorter than that WIX. I found those WIX for around 9USD.
    How much is this in mitsu casas? There is a misu casa being bulit here in our place and if this is good for 10K COI then I'm in luck. (Though this is like twice as expensive as a BD28).
    #1622
    ^around P1000
    #1623
    ^around P1000
    hehe mas mura pa rin pala kahit yung B7045 (P650) na good for 10,000kms din. Yun lang available sa volmax ngaun eh.
    Sana kasama na BD7028 sa April na parating. hehe
    the more choices the better.
    #1624
    Doc, what can you say about SF (SureFilter)? Some of our heavy equipt uses this filter but i can't find the spec's. Heres the site(some dead links) Sure Filter Technology USA - Home
    Im also researching on Standyne, Mahle. Is there a possibility that some manufacturer supplies the filter to them?
    Onether thing i'm investigating is that most Germans uses Hengst but Hengst is supplied by Mann, here's how i found it. I checked for Hengst equivalent for B233 and upon purchase, i cut it open. Found out it was the same as Mann. Hengst hasent replied yet for the micron rating but i requested also to check the authenticity because pics werent the same.
    BTW Hengst is 3x cheaper than the equivalent Mann, even more cheaper than B233.
    Im having filter fettish again.
    Dec 2007
    #1625
    The Surefilters are made in Malaysia by a company called Powerfil. They also make Sakura filters so I'm sure the quality is probably the same, Looks like they use a mixed media like Baldwin instead of strait cellulose. So I guess it depends if the Surfilters have the same specs and use the same media. If so then it looks like it should be a decent filter.
    Jsakura Products, Oil fitlers
    Welcome to Powerfil Auto Parts Sdn Bhd
    Found this on the Hengst looks like they are pretty close to OEM and actually looks better than the MANN.
    oil filter visuals: BMW vs Hengst vs Mann - The Unofficial BMW M5 Messageboard (m5board.com)
    Same here on this BMW filters. This is the Hengst
    This is the MANN
    Mar 2012
    #1626
    The Surefilters are made in Malaysia by a company called Powerfil. They also make Sakura filters...
    Sakura filters are made in Indonesia by the ADR Group of Companies. Even the Sakura filters are
    being counterfeited! JSakura is not made by them. See the Buyer Beware page of their
    website: sakurafilter.com
    As to Mahle, they have their own filter plants. Most of their output is supplied as
    OEM to the car/equipment manufacturers. Their after-market strength is in European
    cars. They are not so competitive in filters for Japanese cars.
    Dec 2007
    #1627
    Counterfiters do not advertise they make your filter, I looks like they are a distributor of their filters not the producers of them.
    In the beginning PowerFil carried many different brands from all over world, providing filtration solutions for different segment. Later in 1995, PowerFil took up the SAKURA HEAVY DUTY line and distribute it across Malaysia as its primary product.
    Now, PowerFil is able to provide a very comprehensive range of heavy duty and commercial filters by a combination of local manufacturing SANKEI ROKI and FILGUARD, and imported range with major brands SAKURA and SURE FILTER on is inventory.
    #1628
    Hi Guys,
    Saan ba makakabili ng spin on oil filter system para sa 1KZ-TE. Tsaka pwede bang naka-horizontal ang pagkaka-install ng oil filters?
    Thanks
    #1629
    Hi Guys,
    Thanks
    Dec 2009
    #1630
    sino gusto nang fleetguard LF3564 cross nang BD28 sa fleetguard... i have two pieces of the filter...
    out of stock ang bd28, ang cross sa fleetguard is LF3564...
    PM nyo ako for anyone who's interested, may nag order kasi sa akin tapos hindi naman pala kukunin... kaasar.
Remote bypass oil filtration
