Dvldoc, called up WIX distributor in Quezon avenue... they have a near size match to that of the pajero gdi... im going to buy from them on Monday,, i am replacing the fleetguard filter i bought from pacer, ill post the pic of the fleetguard filter once i remove it... im not so confident about the authenticity of that filter i bought, that's why i need your opinion when the pictures have been posted.
i saw from the internet that champion labs are the one who manufactures both wix, bosch and other good filters...
what does nominal micron means? cause wix says it 21 nominal microns?
are those specifications mentioned here better than most filters?
thanks
Part Number: 57356
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.402
Outer Diameter Top: 2.685
Outer Diameter Bottom: Closed
Thread Size: 20X1.5 MM
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=6/20
Burst Pressure-PSI: 363
Max Flow Rate: 9-11 GPM
Nominal Micron Rating: 21
