Page 8 of 11 FirstFirst ... 4567891011 LastLast
Results 141 to 160 of 210
    Oct 2011
    #141
    is this product are available in gasoline engine? nissan sentra ECCS 93 model car can equipped with this one?
    Apr 2009
    #142
    sir nakapag install na ba kayo sa Tucson Revgt? any noticeable improvements? interested lang po.
    Apr 2011
    #143
    Quote Originally Posted by CrAyE View Post
    Hi , the racechip is available for gasoline engines, but we only special order them, they are also double the price.
    unfortunately it is not compatible with your car
    Apr 2011
    #144
    Quote Originally Posted by poknet View Post
    hi Poknet, yes the racechip pro give good improvement on the tucson, especially because you have VGT turbo
    Jan 2011
    #145
    Quote Originally Posted by md_alcapone View Post
    just installed RC PRO on my MS GTV. it was indeed a good buy since i used to have an OEM chip for 3 weeks before i got the RC. RC is much better than the OEM chip i had installed. i returned the OEM chip luckily the seller took it back without any hassle. i am doing 100kph at 2000 rpm, is this good?
    i also installed SPRINT BOOSTER and it added more response to my RC. it cut off the lag time when you accelerate and you has 3 settings of your choice. you can feel the response by just SLIGHTLY pressing the pedal and at the medium setting my unit runs at approximately 15kph without pressing the pedal.
    for those who has RC installed also try the SPRINT BOOSTER as add on, i can guarantee a quicker acceleration response.
    the advantage of having the two is that you can really enjoy the paddle shifters of you vehicle.
    also installed HURRICANE air filter...
    dude, can you share the brand nung OEM chip mo before para at least less na options? Currently choosing between RC Pro, DTS and DP Chip kase...TIA.
    Oct 2003
    #146
    can someone please share a photo of a montero (2.5 liter engine) racechip pro installation. where is the plug located on the engine?
    thanks
    #147
    Quote Originally Posted by hinDMaxsiado View Post
    [SIZE=3]
    Boss-among-tunay Jedi,
    Thanks heaps for the Racechip Pro!! Kaya sa yo lang ako eh haha!
    [/SIZE]
    All i can say is that those German diesel EFi-chip developers really know what they're doing! As you saw, i am currently tuned only at the low-lower combo with the two 16-notch dials but the power gains of the Isuzu DMax 3.0 Ddi-iTEQ off-the-bottom all the way up is already very much pronounced even just by seat-of-pants!
    Looking forward to a long-and-satisfying relationship with the chip.
    Best regards also to Boss Mike the Man and Chao!
    ....Inform Boss Mike that my city-driving fuel consumption also improved a lot from a previous 10.5 km per litre prior to the chip installation yesterday to 12.5 km per litre after our one-time test drive, and after driving from Tsikot shop to Quezon City via C5
    Keep up the good work guys!
    Sir.... How's your Dmax with the chip installed now after 2 months of using it? I just recently bought a 2nd hand Dmax 09 and experiencing some turbo lag. I read sa net that installing this chips would help improve the lag.... I'm considering it now.... Thanks
    Jan 2009
    #148
    Boss meron po kayo na pang innova vvt-i? 2009 model po. paki PM na lang po ang presyo. Ty & God bless!
    #149
    I-up ko lang po yung last query ni wolfmanila...Interested din ako sa answer...yung innova ko vvti 2008 model...pwede rin akong i-PM. tia
  10. #150
    Quote Originally Posted by wolfmanila View Post
    Quote Originally Posted by attyallanlatras View Post
    mga bossing, pang diesel lang po ang racechip.. unichip po ang pang gas.
    #151
    afaik may pang gas din ang race chip, hindi lang mabenta or binebenta dito
    Jan 2011
    #152
    sir jedi ask ko lang po if umiilaw ba yong dalawang led located on both sides sa loob ng module? Kasi nabasa ko sa website umiilaw but yung sa akin napansin ko ngayun na hindi pala umiilaw.
    Jun 2009
    #153
    Ok pa rin ba ang tranny ninyo?
    Rated * 350 Nm lang ang torque input ng V5A51. Ang auto-tranny model na nakakabit sa sasakyan ninyo.
    Stall speed ng V5A51 is 2200 to 2700rpm
    Kakayanin pa ng tranny na yan tumanggap ng torque over sa 350 Nm as long as below sa stall speed kasi dudulas lang yang excess torque hanggat wala pa sa stall speed ang torque converter.
    So. let say engine na may maximum torque of 375 Nm * 2,000rpm ay OK lang na ipares sa V5A51
    Originally ay nakakabit yang V5A51 sa 6G75 gasoline engine ng Mitsu. Ang max engine torque ng 6G75 ay 329 Nm lang *2700rpm.
    Di na dapat kinakabitan yan ng Chip. Intentionally de-rated na nga yang makina compared sa manual tranny na Montero. (Nagtitipid malamang ang mitsu sa production at documentation, kaya hindi na dumagdag ng bagong component. lumang tranny pa rin heheh. May future pa yang 4D56, meron pang improvement na 200Mpa fuel pressure, piezo injector at two-stage turbo pero kailangan na talaga ng bagong 6 speed transmission)
    Pero kung andyan na yan, medyo dahan-dahan na lang sa arangkada particularly, coming from complete stop. Saka na lang hatawin kung nasa 3 to 5th gear na.
    * 1st to 2nd gear, kawawa ang underdrive clutch, brake bands, reduction brake at one-way clutches kung beyond their design limit ang lagi nilang tinatanggap. Saka prone sa slippage ang mga components na yan kung laging overloaded kaya wag magtaka kung magkulay itim ang transmission fluid ninyo.
    Mar 2011
    #154
    OT; * arsen, regarding that stall speed. Does that mean MS vgt can't generate 350nM of torque at low 1800rpm. Is the V5A51 code for what 4x2 4sp/5sp or 4x4 4sp/5sp. One last, what are the differences in specs of the 4sp and 5sp a/t of MS vgt esp in speed and torque handling. Tia
    Jun 2009
    #155
    Quote Originally Posted by gundam View Post
    4A/T, 2WD model # is R4A51. Rated torque input capacity is around 300 Nm (basically, it cannot handle the VGT engine), stall speed is around 2100 to 2600rpm
    5A/T, 2WD model # is R5A51. Rated torque input capacity is around 350 Nm, stall speed is around 2200 to 2700rpm
    5A/T, 4WD model # is V5A51. Rated torque input capacity is around 350 Nm, stall speed is around 2200 to 2700rpm
    The VGT engine can generated 350Nm * 1800 rpm however, that engine torque cannot yet be transmitted FULLY to the wheels because the engine RPM is below the stall speed of the torque converter.
    Normally, it will just take a fraction of a second to rev the engine from 1800 to 2200 rpm when accelerating from a complete stop, so the driver will hardly notice the slip.
    Mar 2011
    #156
    Quote Originally Posted by arsen View Post
    Thanks. If you don't mind pwede pa PM ng source mo. Kaya pala konti lang and difference sa takbuhan ng fort2.5 G a/t and gls-v 2w 4a/t. beyond 120kph na mo ma notice difference or if you revv the MS really hard. While in papers ang laki ng difference ng HP/torque.
    Jun 2008
    #157
    just want you to know that im selling RC pro fresh from Germany,very low price (18K)but no installation since nandito ako sa Europe,kayo na po bahala magpainstall,I already sold around 10pcs to my fellow MSCP,just PM me or txt my roaming no 09214003515
    #158
    Any of you guys who have racechip being serviced in Isuzu Pasig? If so, what is their take on this with regards to the warranty?
    I have read here that this racechip should not void the car warranty but I guess at the end of the day it is up to your casa to decide.
    Appreciate some inputs.
    Apr 2012
    #159
    I have a RaceChip Pro that i am trying to fit to my Fortuner 3.0D4D, i have the correct 6 wire harness and have been told that the setting should be Switch 1 = 9 Switch 2 = B The Jumper is on the far left (Nearesr Switches)
    When it is set at that the car runs fine, lots of power and still very smooth BUT
    Under Laod the Engine Light keeps coming on and goes into crawl home mode !!! After Stopping the car and Turning the ignition off then back on again it resets and works as it should do again, BUT EVERYTIME i really put the car under load the engine cuts out, has anyone any ideas ? A Different Chip setting ? Or another Chip i could borrow to see if this is defective ?
    Any help appreciated
    Cheers
    Crawford
    #160
    nag limp mode yata.. try lowering the settings
RaceChip Pro Tuning Chip Official Thread
