Page 1 of 6 12345 ... LastLast
Results 1 to 10 of 51
    Feb 2017
    I am new to coolant/cooling system and I am a diyer I want your opinion about coolants..
    Is it necessary to do a coolant flush?
    How would we know if there are build up already so flushing is needed?
    Is radiator cleaning the same as flushing the coolant?
    Thanks in advance guys.
    Sent from my SM-G532G using Tapatalk
    How to SUPER FLUSH your Cars Cooling System - YouTube
    Feb 2014
    what's the car? and have you been using the proper coolant?
    how old is the car?
    Feb 2017
    K14B 2years 45k mileage.
    drain and fill every year after the 1st coolant change...
    Feb 2014
    suzuki? why are they still using old-fashioned coolant these days we already have OAT organic acid coolants that last 10 frikkin years
    just drain then fill your coolant w/ the correct type. i wouldn't bother flushing, coz you'd be replacing the old-fashioned coolant so often anyway...
    Feb 2017
    You mean no flushing required?
    no need for flushing....rust happens when owners use water alone...
    Between 2-3yrs ang coolant lalo na kung high mileage.
    With that period kung hindi naman bababa sa minimum level ng reservoir yung coolant okey na na hindi mai-sakto sa high level.
Coolant flush or refill?
