Results 1 to 20 of 51
    Feb 2017
    I am new to coolant/cooling system and I am a diyer I want your opinion about coolants..
    Is it necessary to do a coolant flush?
    How would we know if there are build up already so flushing is needed?
    Is radiator cleaning the same as flushing the coolant?
    Thanks in advance guys.
    Sent from my SM-G532G using Tapatalk
    How to SUPER FLUSH your Cars Cooling System - YouTube
    Feb 2014
    what's the car? and have you been using the proper coolant?
    how old is the car?
    Feb 2017
    K14B 2years 45k mileage.
    Feb 2014
    suzuki? why are they still using old-fashioned coolant these days we already have OAT organic acid coolants that last 10 frikkin years
    just drain then fill your coolant w/ the correct type. i wouldn't bother flushing, coz you'd be replacing the old-fashioned coolant so often anyway...
    drain and fill every year after the 1st coolant change...
    Feb 2017
    You mean no flushing required?
    no need for flushing....rust happens when owners use water alone...
    Between 2-3yrs ang coolant lalo na kung high mileage.
    With that period kung hindi naman bababa sa minimum level ng reservoir yung coolant okey na na hindi mai-sakto sa high level.
    Jan 2008
    Quote Originally Posted by Noel Salisipan View Post
    Replaced coolant of my 5 year old car. No significant dirt or rust found..
    Replaced coolant of my 18 year old car. Suprised that no rust or dirt found too.. even the main ports from the engine looks new!
    Never use water talaga sa cooling system to prevent rust formation
    10 years na ngayon ang mga bagong kotse, bago magpalit ng coolant. It should be written in your manual.
    Feb 2017
    Nakalagay po sa manual ko R eh. R= replace, wala sa manual refill kaya mejo ndi specific.
    Feb 2017
    E diba po pag nag flush ng coolant, ginagamitan ng pure distilled water hanggang luminis, edi masama pala yun po?
    AFAIK the reason behind doing coolant flushes is it gradually becomes electrolytic over time. After a few years kahit visually malinis pa yung coolant it eventually becomes an electrolyte like plain water, which can cause galvanic corrosion especially if the engine and radiator use different metals (usually iron in the engine block and brass/copper in the radiator). Recommendation from Toyota in Vacaville CA is to flush coolant every three to five years or 30k miles.¹
    ¹ How often does your car need a coolant flush?
    Apr 2014
    Note:
    distilled water is generally good sa radiator
    Tap water and mineral water is bad.
    Yan ang difference ng water terms sa radiators.
    Sep 2018
    Quote Originally Posted by chronicle View Post
    Note:
    Thanks for sharing this information. Very helpful especially sa mga newbie motorists :D
    What car is that? *danegoesonline
    Sep 2016
    Ano po ba ang nilalagay sa loob ng radiator cap pag binuksan? Direct Coolant po ba or distilled water lang po ba?
    Quote Originally Posted by ReggieMar View Post
    distilled? thats for emergency use only. kalawang habol mo nyan...
Coolant flush or refill?
