Results 41 to 50 of 51
December 28th, 2019 02:21 AM #41
The cooling systems includes passages inside the engine.
simply draining the radiator does not remove the coolant entirely. if you really want to remove the coolant there are ways to do so. you can remove the radiator hoses top and bottom and you can also remove the thermostat as that is "closed" on a cold engine. by doing these all that coolant should go down the drain. you can do this twice to complete change to a different coolant.
- Jan 2019
- 19
December 28th, 2019 10:48 AM #42
December 28th, 2019 11:08 AM #43
- 52,731
December 28th, 2019 11:54 AM #45
- 52,731
December 28th, 2019 12:22 PM #46
December 28th, 2019 12:23 PM #47
December 28th, 2019 12:59 PM #48
Ako usually drain lang from radiator plug then flush with water. Pag clear na, refill it with ready to use prestone coolant.
- 52,731
December 28th, 2019 01:03 PM #49
- Jan 2008
- 4,726
December 28th, 2019 05:09 PM #50Ako drain and fill lang..pag check sa drained coolant.. malinis naman
Xiaomi E-Car
