Page 4 of 5 FirstFirst 12345 LastLast
Results 61 to 80 of 96
    #61
    Quote Originally Posted by ElizaBeth07 View Post
    hey, Help me out in this confusion!! Is it good to change oil? Will it affect my car's appliances?? Best Thermostat
    change oil... of the car's engine? it is a requirement, po.
    nasa owner's manual ang schedule and oil specifications. best to stay faithful to it.
    no, it will not directly affect your car's appliances.
    but if something happens to the engine because of oil issues, then most of those electrical appliances will be affected, because they get their electricity from the alternator that is run by the engine.
    bot yan doc lol
    #63
    bot yan doc lol
    sumbong kita kay cathy.
    let her be doc. he he he
    #65
    noted.
    maganda gabi ngayon.
    mukhang a-araw na bukas.
    makapag-laba nga...
    Feb 2012
    #66
    Any one using 0w20 or 5w20?
    The Toyota Corolla manual specified both oil, but most of us here either use 5w30 or 5w40.
    (Currently using 5w30 for Altis 2011). Will it be too thin kaya for our conditions here?
    I really would wanna try and go back to what the manual recommends.
    Sep 2005
    #67
    I only use regular oil sa Toyota Avanza... basta change oil every 6 months.. mababa naman odo.. Toyota uses 20W50 for regular oil sa gas engines..
    Quote Originally Posted by gearhead000 View Post
    Jan 2016
    #68
    Wala kasing 5w20, mas common ang 5w30, 0w20 naman sobrang mahal. 5w30 ako sa 2013 Civic ko.
    Jul 2013
    #69
    IMO. if your car is working perfectly on the current oil you're using, better stick with it.
    it's a 10 year old engine... oil seals are not what they used to be.
    Sep 2021
    #70
    Sa init dito sa clima natin, di bagay ang 0W-20. I don't use it, even if my manual says its the preferred viscosity.
    Yung manual was written for a "Generic" market, not specifically for a market sa tropics, kaya ang daming translation din, tapos may disclaimer pa for variants in EU or Asian markets.
    Hindi naman masisira car mo if you use 0W-20 oil here, but personally, I don't recommend it. Kahit sinthetic pa ayan, ang lightest viscosity sa clima natin should be 5W-30 if your emphasis is more on engine protection rather than increased fuel economy.
    #71
    IIRC 30 weight oil is only good for up to 30°C. I try not to use anything lower than 40 weight for my cars.
    Source: Rymax Lubricants Holland
    Also with our climate the "W" rating doesn't matter at all. It represents the oil flow at 0°F (-17.9°C).
    If SAE 30 is good for 5°C to 30°C, 5W30 extends the lower operating range to -35°C. It's irrelevant to us.
    #72
    my two cents' worth,
    from what i understand,
    the W rating may be of importance in temperate countries where it snows,
    but in our country, that W rating is of importance because some engines have oil passageways so narrow, thicker oils may have difficulty in effectively traversing them whilst the engine starts from cold.
    the other number naman, is the temperature when the oil starts its effective lubrication. by that temperature and higher kasi, the 0 rated oil may not be an effective lubricant anymore.
    when you have a multigrade oil, the effective lubrication of that oil is a combination of the two or more grades of oil.
    see dr. kamiya's diagram above.
    the combination of oils, effectively increases its temperature range.
    Aug 2008
    #73
    Sa init sa atin, I'll stick to the thickest viscosity(and highest W) na recommended sa manual.
    Sent from my SM-A125F using Tsikot Forums mobile app
    #74
    Quote Originally Posted by jigeloh View Post
    back in the day, when engine blocks were made of iron,
    the best oil was the walang-kamatayang SAE40 or 50.
    laluna kung pinaghaluan nang pertua!
    highs. the good old days...
    Jan 2008
    #75
    Meron naman naka indicate sa manual yung temp range na dapat gamitin na oil viscosity..
    Modern engine mas tight ang tolerances.. kaya mas ok yung thinner oil.. 5w30 na for me yung swak sa fuel efficiency at protection sa heat sa atin.. may mga bansa pa nga na mas mainit.. katamtaman pa lang here.. ang kalaban talaga sa atin ay traffic at long idling
    Feb 2012
    #76
    The reason I asked is I've read several owner's manual and for the newer gen engines recommended viscosities are 0w20 or 5w20.
    So I did a quick search with our online shops and they're now quite readily available and more importantly, very much affordable.
    Used to be talaga na either walang mga 0 and/or 20 weight oils dito sa atin. There was a time ang popular pa nga is 20w50.
    I do remember with my 9th gen the recommendation is 5w30, but during that time it was something quite rare thus the use of 5w40.
    With the newer generation, manual says 0w20/ 5w20 pero again probably just 3 years ago rarepaps pa dito ang said viscosities.
    As mentioned, today they are quite aplenty from the respectable brands, and with prices very competitive with the popular viscosities.
    Mamili ka between OEM's like Ford (Motorcraft), Mitsubishi, Honda, Hyundai, Suzuki, or manufacturers like Aisin, ACDelco, Idemitsu, Mobil 1, etc.
    That chart though is quite an eye opener, though I may still not be using 40 weight on my 10th gen.
    It spelled for us in an easy to digest way the usage of these various viscosities, either monograde or multigrade.
    I may probably stick with 5w30 going forward. It's only a 0.5~0.7% gain in efficiency with the thinner oils.
    Jan 2016
    #77
    How much is the cheapest 0w20 you found?
    Feb 2012
    #78
    For the 0w20:
    * ACDelco Supreme Plus API SN (430/L)
    * Aisin GreenTech+ API SN Plus (1,477/Gal) 7.31 Promo
    * Honda FS Motor Oil API SN (465/L)
    * Suzuki ECSTAR F9000 API SN (530/L)
    For the 5w20:
    * Amsoil OE 100% Synthetic API SN Plus (497/L) 7.31 Promo
    * Ford Motorcraft FS Motor Oil API SN (450/L)
    * MAG 1 High Mileage Synthetic Blend (550/L)
    * Mobil 1 Advanced FS Motor Oil (600/L)
    Sa weather natin sa Pinas, W30 talaga minimum na ideal. Sobrag nipis na yung W20 pababa imho. Yung W40 nga okay din eh lalo na kapag uminit na makina, mas swabe na yan.
    Ang baba nga ng viscosity na nilalagay ng honda sa crv diesel eh. Para siguro tipid sa diesel consumption.
Is it ok to have changing oil viscosities?
