Results 1 to 10 of 33
Threaded View
- Jan 2018
- 42
February 6th, 2019 11:10 AM #7Hello! I had my oil change sa Shell Station lang (first time outside of CASA) and they said that its ok to reuse the drain plug and gasket during the oil change. This is when I ask them diba you should replace the gasket before you screw it back? I'm worried since reading posts here that you should change the gasket every oil change. Will it really result to loose thread down the road or succeeding oil changes?
It is repairable. But as oj88 mentioned, it is messy (when repaired) and best used as a last resort.
Liquid tire sealant
