Quote Originally Posted by ferddie View Post
Hello! I had my oil change sa Shell Station lang (first time outside of CASA) and they said that its ok to reuse the drain plug and gasket during the oil change. This is when I ask them diba you should replace the gasket before you screw it back? I'm worried since reading posts here that you should change the gasket every oil change. Will it really result to loose thread down the road or succeeding oil changes?
It should be single-use only. You might get away with reusing it a couple of times but they're so cheap that there's really no excuse not to replace them every time. A 10-pack from Lazada is just around P200.
