Page 4 of 11 FirstFirst 12345678 ... LastLast
Results 61 to 80 of 217
    #61
    Yes. I will insist that they fix the problem for free. It was in perfect condition before it was brought there for PMS.
    Oh wow. How did these valve problems happen? Baka nga daw nagasgasan, Factory defect? I do the PMS religiously so I have no idea how this problem started. How much is a top overhaul anyway? Is it that bad na I am better off selling my car?
    possibility lang naman yan. kung hindi naman severe yung hammering sa valve stem tips e hindi mo need ng top overhaul. ang case lang for a top overhaul e kung sobra na-hammer yung tips ng valve stems at may possibility na ma-dislodged yung valve stem keepers at mahulog yung valve sa loob ng cylinder. pero kung slight damage lang ok pa yan, mag-manual adjustment lang ng konti to reset the hydraulic valve lash clearances. do get a second and third opinions before you agree for an overhaul. alam mo na, baka kasi nakita na "uy out of warranty na, girl driver..." at ginawan ka ng kalokohan ng casa mo. style rapide ba.
    ^ It seems hindi nga self-adjusting ang 4afe.
    Does 4A-FE need valve clearance adjustment or not
    Puwede lang umingay yan kapag may nagalaw daw sa loob nang engine. Anak nang....
    #63
    I really hope so. Anong tawag sa manual adjustment ng valve? Mahal din ba yun?
    I won't agree to a top overhaul sa casa because I cannot afford it. Saka relatively bago pa yung makina maibababa na
    4AFE ba yung sa 10th gen ko? or sa big body yan?
    #64
    kung hindi nga hydraulic lash adjusters ang gamit nyan then normal valve tappet adjustment lang. para ka lang nagpa-tune up, P500 sa suking mechanic.
    Mar 2013
    #65
    Mukhang simpleng problema lang naman yan Cath. Wag mong pagawa sa casa pag humirit ng top overhaul.
    OT:
    Na ban pala si Makoy lover aka "utak lugaw"
    Kupal kasi eh.
    Sep 2006
    #66
    Kung change oil lang yun ginawa ng casa i think mahihirapan kayo na free yan malamang natapat lang sa kanila yun pag ingay ng engine. Puwede din nangyari napa start ng walang oil meron naki alam na ibang gumagawa.
    #67
    Quote Originally Posted by ClaNker View Post
    OT:
    Kupal kasi eh.
    Lesson learned: Don't go to casa after warranty period.
    I really hope they will not diagnose an overhaul. I'm praying that the theory of our car gurus are correct that is just a tappet issue
    Quote Originally Posted by Langabe View Post
    Kaya nga nakaka kaba na pinuntahan pa sa bahay yung auto. Baka may nagkamali nung ginagawa yung PMS. I never imagined it would have an engine problem kasi alaga sa PMS
    Mar 2013
    #68
    Indeed.
    Yes, looks like a tappet issue only. Had the same problem with my old mazda before, I just ignored it... Tappet noise is music to my ears after all.
    But since you're not me then have it checked outside.
    #69
    Hehe same here. Also have tappet issues. Ignore lang. Still running 100kph on expressways btw. Tinanong ko si suking mechanic 600 lng daw pagawa.
    Posted via Tsikot Mobile App
    Jul 2011
    #70
    Quote Originally Posted by Lew_Alcindor View Post
    The self adjusting thing was the biggest BS I have heard about 4afe. I downloaded a service manual about 4af/4afe and nowhere it says that tappet clearance is self adjusting.
    I see, thanks for the heads up.
    Ill do further research about this,
    seems like all those mechanics that i inquired about my noisy tappets
    (back then when i had the car) didn't just know how to adjust then,
    as they are all saying that it is self adjusting, even thou my brother's
    2e engined powered corolla has been adjusted a couple of times.
    sorry for those i misinformed.
    #71
    What causes those tappet issues ba? Wear and tear e 4 yrs old pa lang car ko
    Jul 2011
    #72
    normal wear and tear ata. sa GE every 30K ang recommended inspection & adjustment.
    #73
    Thanks everyone. I really hope tappet lang. They did not adjust on 30k kasi self adjusting daw.
    Ang huna na pala ng new cars ngayon.
    Jul 2011
    #74
    baka depende sa car, iba-iba ang recommended interval for valve clearance adjustment.
    nung 30K PMS ko outside ng casa nitong april lang, sabi nung mekaniko di pa raw kailangan nung pinakinggan nila yung tunog ng makina.
    #75
    Makes me wonder why my ae101's engine remained quiet for 18 years.
    Sabihin ko sa casa bukas yun muna valve clearance i check nila at hindi yung top overhaul agad.
    #76
    pwedeng sinadya. i keep wondering why they came to your house. ano yun, para di makawala ang victim? puntahan na agad at baka sa iba pa pagawa?
    basta sa iba mo pagawa huwag sa kanila.
    #77
    Bagay ito sa They dont make cars like they used to thread.
    Palitan mo ng diesel para masanay ka sa engine noise, puro self adjusting na ang CR engines ngayon
    Correct, wag mo pagalaw ang makina.. Lalo lalaki ang problema mo sa casa kapag nabuksan ang ibabaw. Or if you can contest na last-touch job baka gawin nila for free/out of goodwill + with warranty.
    #78
    We were supposed to bring the car to the casa this morning but the sound was really loud. I called my service advisor and had him listen to the sound of the engine and I said ayoko itakbo baka tumirik so they said sent people to my house instead.
    I will not pay if they charge me
    #79
    Then they won't release your unit.
    #80
    ^hahaha. I will use the last touch argument.
Oil Did Not Circulate - Damaged Engine!?!
