Page 11 of 11 FirstFirst ... 7891011
Results 201 to 217 of 217
    Quote Originally Posted by Monty View Post
    Cathy, yung pag taas ng rpm pag engage ng compressor ngayon lang ba nangyari? Yung ibang kotse namin tumataas ang idling.
    Posted via Tsikot Mobile App
    Not as noticeable as before yung change ng idling. Dati kasi dati sa sobrang quiet ng engine pag nasa stoplight ako na matagal, bigla ako mapapacheck ng auto kung umaandar ba talaga. hehe.
    Quote Originally Posted by vvti2.0 View Post
    Wala ako alam sa kotse, kasi ang alam ko electric fan ang gamit ng kotse boths a aircon and radiator, but anyhow normal tumaas ang idling kapag nagkick in ang compressor mo, but 1k RPM is way high, 850 to 900 ang normal nyan. Aabot lang ng 1k to 1.5k RPM during cold starts, as in yung di pa na warm up yung engine sa umaga, pero instantaneous rin yan.
    Pwedeng salarin ay servo kung wala ka idle, pero dahil may idle up ka, chances are ok naman ang servo.
    Tell them ang taas ng idle up mo, mukhang ni-adjust nila idle mo, magastos sa gas yan, ano na ba yung idle rpm mo?
    Mga nasa 1500 nga ata pag cold start. Masama ata yung habit ko na pag start ng engine, on agad ng aircon?
    when the engine is already at operating temperature and there's idle surge it could be the MAP sensor
    also cause of erratic idling
    Is it normal for a 4 year old car to have defects in the MAP sensor? Is it easy to have that checked lang?
    #202
    I'd guess as the car gets older, umiingay yung makina. Dati ganiyan din yung FD namin out of the casa. I've actually started the car again nung naka on na (heard unnerving buzzing sound, do not want to hear that ever again).
    Now on idle and at low RPM rinig ko na yung makina kahit aircon off.
    Doesn't seem to be a problem with turning the aircon on as soon as you turn on the car. We have a 12 year old Camry going strong despite having the AC on full blast right on engine start (hit the AUTO button hehe).
    Yung MAF sensor, baka lemon part lang nakuha mo? :/
    Quote Originally Posted by mda View Post
    Yes this happened to me several times
    Habit ko rin yan, turn the key then push auto. hehe. I am paranoid nga that I got a lemon car kasi during warranty period, casa had to replace a part in the AC kasi biglang umingay, blower motor ata. Yung power steering ko pinaltan din (45k+) within warranty kasi nabibigatan ako sa steering minsan, sabi ng casa okay naman hindi nila na experience during testing but they will replace it anyway I guess my only consolation e maayos kausap yung casa. But still nakakainis na kaya ka nga nag brand new para walang abala at sakit ng ulo.
    idle surge can be caused by unmetered air going into engine
    If that is what's wrong with my car, I hope it's nothing major.
    #206
    In other words baka may singaw.
    Joke lang... If I remember correctly, yung altis ng sister ko before ganyan din. May surge ng idle paminsan minsan, Lalo na sa shifting.
    Compression test, maf sensor check, binarahan ko intake. All signs ok. Kaya I did not worry about it anymore.
    This was a 2004 model.
    Jul 2006
    #207
    Nanganak problema?
    Trade in mo na sa Fortuner yan.
    :D
    Sep 2013
    #208
    Ano nga ba yung throttle body? Sabi kasi walang sludge, nakalagay pa sa report nila. Hindi naman nanginginig, nagbabago lang idling. Weird din kasi kanina naka stop ako tapos tumaas yung idling bigla as if inapakan ko yung gas. Ayoko na rin isoli sa casa kasi sinasabi nila nothing is wrong at almost 2 weeks ko din iniwan yung auto sa kanila.
    Ang throttle body nililinis ito usually lagpas 100,000kms.
    Nakakaloka naman na linisin agad sa kakarampot na tinakbo ng kotse mo.
    Jun 2014
    #209
    Wow salamat sa thread na to. I learned a lot sa mga insights. Well, I had that knocking sound dn, then we changed all the Spark plugs and it was eliminated. And we also found out na, we need to do an overhaul daw and replace piston, since ang makina ko daw ay naninira na ng SP, by merely basing on the significant oil content sa 2 SP ko. Is this true? or a top overhaul will fix this leaking oil in my SP?
    How old is your car and what is the km reading?
    I hope that is not the case with my car!
    Jun 2014
    #211
    Hi Cath, 96 un skin. lolo na hehe
    As far as I know, pg may knocking sound ka 2 lang ang basic na dpat natin icheck coils and spark plugs. Pag may sira na isa sa 2 na yan tska plg dpat chineck un engine parts.. just like nun skin, nasira na un SP, which ang dahilan e nalunod ng oil, na kng saan may problem na mismo sa makina.
    Ako after reading mula umpisa ng thread na to naniniwala din na walang problem un car mo. mganda ang maintenance mo, minsan tlga need mo mglaan ng oras para mkita mo kng ano un ginagawa ng mekaniko. Ako kc sa Shell ngppatune up, mga 1-2 hours lang tapos na.
    Aug 2010
    #212
    Quote Originally Posted by Zac_espaņol View Post
    tune up today is not the same tune-up with older cars AFAIK. Funny, because why? tune up today just replace SP and clean air filter. nothing more.
    Oct 2013
    #213
    Oo nga, parang kalokohan na ang tune up sa mga EFI ngayun.
    Sep 2012
    #214
    There are times na kailangan pa rin ng tappet adjustments... Hindi na nga lang stated yun sa manual.
    Sa spark plug, dagdag nyo na yung proper gap
    Sent from my Windows Phone 8 using Tapatalk
    Oct 2013
    #215
    Naka iridium ako, di ni gagap yun.. Sa mga VVTi rin, murang mura lang replacement ng spark plugs... auto adjust ata yung tappet.
    Jan 2010
    #216
    To reduce engine weight, most engines are now overhead cam with non adjustable cam follower buckets. The only time they need adjusting is after valve lapping or valve grind.
    Jun 2011
    #217
    Original post sounds like VVTI mulfunction.
Oil Did Not Circulate - Damaged Engine!?!
