Results 21 to 40 of 41
    #21
    Nope. I've tried it many times with a calibrating bucket. 10L is 10L, whether fast or slow.
    But, if magpapafull tank ka, better to use the slow setting. Pumping fuel is like soda, nagbububbles pag masyado mabilis, so keep it slow so you can let the fuel settle and you get to fill the tank talaga.
    Most pump attendants naman pag magfufull tank, 1 or 2 lang gamit, not 3 (fastest).
    thanks bro, naliwanagan ako!
    Nov 2014
    #22
    makikita ba natin yung setting ng nozzle from LCD display ng gas pump?
    #23
    Noob question guys.
    Wala ako alam sa sasakyan and this is my first time to have one.
    Nung nilabas namin sa casa yung sasakyan nag pa gas kami sa caltex silver unleaded... Advisable ba or it's must na sa caltex ulit ako mag pa gas?
    If hindi naman must, Do I need to empty the fuel first bago ako mag pa gas sa ibang gas station like petron or shell?
    Thanks!
    Sir dhisky,
    Congrats po sa New Ride,
    About naman po sa fuel pag dating sa gasoline, kahit anong brand pa yan at pag haluin ang octane rating, no problem po yan, sa long as po na "Gasoline", wag lang "Diesel"
    #24
    Quote Originally Posted by sp00nman View Post
    Nope. Fill rate is set by the lever that's on the pump nozzle.
    Most people prefer the fastest fill rate so they can get on with their journey quicker. If you want it slower, all you have to say to the pump attendant is "uno lang ha". This refers to just the first click of the nozzle lever which corresponds to the slowest fill rate.
    #25
    [QUOTE=
    About naman po sa fuel pag dating sa gasoline, kahit anong brand pa yan at pag haluin ang octane rating, no problem po yan, sa long as po na "Gasoline", wag lang "Diesel" [/QUOTE]
    all current gasoline fuels are mix-able with each other, with no ill-effects.
    just be sure your engine's octane requirement is met.
    same with diesel fuels.
    Nov 2014
    #26
    SALAMAT, Sir!
    Laking tulong nga mga inputs mo.
    Another Q, ilang liters pa usually pag nag warning light na to empty (E) ?
    Or depende rin sa car, ours is Ertiga?
    TIA ulit
    #27
    SALAMAT, Sir!
    TIA ulit
    yespo.. it depends on the car. some owners' manuals have that info mentioned.. new owners should scan that manual.. especially if the owner is a noobie.
    #28
    SALAMAT, Sir!
    TIA ulit
    It really depends per car, but usual is about 8-10L.
    I once drove my Ranger from Camarines Norte to Camarines Sur (100+ km) with the fuel warning light already on and the needle already pointed at E, umabot naman. When I filled up, I consumed 74L, so it means I still had 6L in my 80L tank.
    More recently I drove my Vios up until the needle was already way under the E mark, but when I filled up, 32L palang so may 10L pa since 42L ang tangke.
    Point is, when the warning light shows up, fill up already. But if you can't, there's enough left in your tank to get you to the nearest gas station you can find.
    Nov 2014
    #29
    Thanks. For sure 100-120Kph takbo mo or more pa. Vios talagang matipid ata. Plan ko nga din pa full tank pag nag E na, but since every week me rollback P500 lng muna pakarga ko, hehe sayang din.
    *dr.d - salamat and sa manual namin generic lang sinabi at conservative na mag refill once mag warning na
    #30
    generic manual.. oh well..
    yes, i also fill up asap when that warning light goes up.
    i also played chicken with the fuel gauge in my earlier years, and i lost. fortunately, the gas station was within walking distance. the real problem was where to place the fuel and bring it to the car..
    Nov 2014
    #31
    Suzuki Ertiga talaga yng manual, it's just yng suggestion lang at safe side na mag gas na.
    Usually nagdadala ako ng empty bottle ng mga mineral water n 5L.
    #32
    some gas stations will refuse to sell you gas if you do not have the requisite regulation "official" fuel container.. but... good luck just the same.
    #33
    Should be standard for all stations, but yung iba siyempre ayaw mawalan ng benta just because their customer is using a mineral water bottle.
    Dec 2014
    #34
    Thank you guys.
    By the way do I need to turn off the engine or kahit hindi na?
    Nov 2014
    #35
    Thank you guys.
    There's a sign to switch off the engine. And the gas boys will also tell you to switch off the engine if you didn't already.
    Dec 2014
    #36
    Switch it off for safety. Malay mo ang naikarga diesel pala tapos nakaon ang engine. At least maagapan pa kahit papano. E kung nakaon. Ayun pumasok na agad sa engine. For safety switch it off na lang.
    Nov 2014
    #37
    This thread is really informative. Now I'm wondering if the extra hatak I felt when I tried high-octane fuel was just a placebo effect.
    Oct 2013
    #38
    turn off engine... for safety sa wallet and sa environment...
    *jut703 - baket mas mahal ang presyo ng gasoline/diesel products sa pandacan compared sa iba lugar?
    * kai s. - depende kung ano ride mo...
    #39
    Quote Originally Posted by Stigg ma View Post
    Pricing has very little to do with distance from supply point. Rather, it's dictated by market forces. Simply put - oil companies sell high in Pandacan because they can. None of the majors in the area want to start a price war, while the small players just follow suit and also enjoy the huge margins they're making.
    Once na may manggulo sa presyo, bababa lahat ng iba and boom goes the price war. Good for consumers, bad for business. This is the case in all price war areas. My favorite example is Alabang. The Petron station in Filinvest is owned by Ramon Ang himself. It serves as a flagship site that pumps out almost 1 million liters per month. He doesn't care if he makes pennies per liter, as long as he has the volume. Everyone else just followed suit to stay competitive. Kaya ayun, ang baba ng Alabang prices.
    #40
    errr.. who's ramon ang, and why does his name have to be mentioned?
    pennies per liter x big volume is typical chinese formula...
    and is just possible, that location is what brings motorists to that station and not price?
Noob Question: Same gas station?
