Results 21 to 30 of 41
- Nov 2014
- 454
January 18th, 2015 10:59 PM #22
January 19th, 2015 01:44 AM #23
January 19th, 2015 02:20 AM #24
Nope. Fill rate is set by the lever that's on the pump nozzle.
Most people prefer the fastest fill rate so they can get on with their journey quicker. If you want it slower, all you have to say to the pump attendant is "uno lang ha". This refers to just the first click of the nozzle lever which corresponds to the slowest fill rate.
- 54,228
January 19th, 2015 02:29 AM #25[QUOTE=
About naman po sa fuel pag dating sa gasoline, kahit anong brand pa yan at pag haluin ang octane rating, no problem po yan, sa long as po na "Gasoline", wag lang "Diesel"[/QUOTE]
all current gasoline fuels are mix-able with each other, with no ill-effects.
just be sure your engine's octane requirement is met.
same with diesel fuels.
- Nov 2014
- 454
January 19th, 2015 11:45 AM #26
- 54,228
January 19th, 2015 11:52 AM #27
January 19th, 2015 11:53 AM #28
It really depends per car, but usual is about 8-10L.
I once drove my Ranger from Camarines Norte to Camarines Sur (100+ km) with the fuel warning light already on and the needle already pointed at E, umabot naman. When I filled up, I consumed 74L, so it means I still had 6L in my 80L tank.
More recently I drove my Vios up until the needle was already way under the E mark, but when I filled up, 32L palang so may 10L pa since 42L ang tangke.
Point is, when the warning light shows up, fill up already. But if you can't, there's enough left in your tank to get you to the nearest gas station you can find.
- Nov 2014
- 454
January 19th, 2015 12:15 PM #29Thanks. For sure 100-120Kph takbo mo or more pa. Vios talagang matipid ata. Plan ko nga din pa full tank pag nag E na, but since every week me rollback P500 lng muna pakarga ko, hehe sayang din.
*dr.d - salamat and sa manual namin generic lang sinabi at conservative na mag refill once mag warning na
- 54,228
January 19th, 2015 12:22 PM #30generic manual.. oh well..
yes, i also fill up asap when that warning light goes up.
i also played chicken with the fuel gauge in my earlier years, and i lost. fortunately, the gas station was within walking distance. the real problem was where to place the fuel and bring it to the car..
safe ba along Rizal Stadium? Along Adriatico? Google Maps
Recommended Parking Near De La Salle (Taft)
