Page 6 of 6 FirstFirst ... 23456
Results 51 to 53 of 53
    Nov 2017
    #51
    it is the valve cover gasket. for an old car. there could be more things to do. we have a gasket keep things in and out. replace as soon as possible.
    1998-2008 Toyota Corolla Valve cover gasket remove and install - YouTube
    Sir, thank you very much sa expert advice... natatakot lang ako at baka bigla na lang akong itirik sa daan.. kaya from time to time check ako lagi.
    Nov 2017
    #52
    you might tighten the valve cover bolts a bit, if you are in a financial bind.
    if it does not stop the leak, and i believe it won't, what with its age, then replace it (the valve cover gasket).
    it's just a valve cover gasket, sir. it's not that expensive. but if the oem is too expensive for your taste, use a cheaper replacement brand. the stresses there are "not too much", i feel even a cheaper gasket will do fine.
    good luck.
    Quote Originally Posted by K.I.L.L. View Post
    They usually call this service a top overhaul.
    Sent from my Android using Tsikot Forums mobile app
    Mga sirs, estimate price po ng top overhaul? Para mpag handaan. Thanks! Medyo tight ang budget kaya kailngan sure na pag pinagawa. Thank you!
    Jun 2009
    #53
    Hello tsikot. Any reputable shops around mandaluyong or malapit na marerecommend ninyo pra magpa full overhaul? H100 ang car. Tia
Need na ma overhaul yung engine?
