Page 2 of 5 FirstFirst 12345 LastLast
Results 21 to 40 of 82
    #21
    Quote Originally Posted by userfriendly View Post
    You can use the RP 5w40 for diesel but its only rated as CF. CF rating while still in use, has been surpassed by newer standards. As I stated earlier, the RP 15w40 or 10w40 are the RP variants for diesel engines.
    so wich should i get sir?
    Jun 2006
    #22
    check your manual. get the viscosity and grade recommended by your manufacturer.
    #23
    Quote Originally Posted by s_quilicot View Post
    wich one would be the best in quality and performance ..
    Royal Purple 5w-40
    Mobil1 Delvac 5w-40
    Castrol Edge 5w-40
    or 5w-30?
    all mentioned above are fully synthetic ..
    performance po bahala na kung mahal ..
    whats the best among the 3?
    Nov 2003
    #24
    before you compare you have to first find out which viscosity is recommended by the engine. then you do a comparison based on the oils with that specific viscosity and with api ratings that meet the requirements.
    for hondas the thickest you should go is a 10w40 unless you are turboed or have other mods which is when you can play around with the viscosity.
    yes, RP is straight from the US. Most of the Motul oils in the market are packed/made in asia na and not in France. it's on the label at the back. you can look at it.
    #25
    Quote Originally Posted by speedyfix View Post
    sir miggs 5w-30 pala .. nakalagay sa manual and allover sa engine ..
    available din ba sa inyo mobil one DELVAC?
    whats the best that you can recomend to me for a viscosity of 5w-30 ..
    have plans kasi to visit your shop around 1st week of april ..
    TANABE brakepad or much better brands pala for trooper 4jx1 din ..
    Nov 2003
    #26
    sorry we do not have delvac. the only 5w30 we have is royal purple full syn oil. you can get the product sheet here: http://www.royalpurple.com/motor-oil-pp.html
    yes meron tanabe for the front lang though.
    #27
    Sir speedyfix if oil lang ng RP 5W-40 fully syn magkano?
    Nov 2003
    #28
    SRP for the 5w40 is 550/liter.
    Jul 2006
    #29
    Clarify ko lang, if I will avail your promo on your signature, Php 2,100 for 4 quarts not liters(malaki diffrence)-any viscosity + oil filter + labor; applicable ba siya sa RP 5w-40? as well as my ride is a diesel so my oil filter I hope ay may stock kayo diyan.. 2,100 pa din ba yung price?
    #30
    I'm getting better fuel economy with Royal Purple... around 5-7% better than Motul.
    I've used Motul for quite a long time... 40,000 kilometer I think... before I switched to Royal Purple.
    :cool01:
    __________________
    bigbigcar.com Review: Toyota Avanza 1.5G
    #31
    sir mazda what viscosity are you using? im planing to switch to RP too ..
    Quote Originally Posted by mazdamazda View Post
    :cool01:
    __________________
    #32
    I've used 10W-30 before... using 10W-40 now just to see if there's any difference.
    Just use whatever is recommended for your engine.
    __________________
    #33
    5w-30 nakalagay sa manual for my 4jx1 ..
    kay speedyfix ka perform PM?
    #34
    Sir do you have a 6 quart oil change promo package? Car is a Mazda3 2.3l can you provide or do I have to bring my own filter? Thank you.
    Jul 2006
    #35
    Since hindi pa nagrereply si speedyfix, I found out sa website nila na unfortunately the 5w-40 is hindi kasama sa 2100 na presyo which includes labor and oil filter. so yung signature niya na 2100=any viscosity of RP + oil filter + labor is mali, misleading siya.
    Nov 2003
    #36
    grid, the promo is aimed towards passenger gasoline cars which only consume at most 4 liters of oil (when they consume more we just add the cost of the extra oil to the total). the 5w40 oil actually just arrived and pricing is different for it kaya di sya kasama sa promo, i haven't had the chance to re-do my signature yet. sorry if you think it is misleading but i cannot fit all the details in the sig since it is not permitted by the system.
    in any case, depending on your car, 4 liters will probably not be enough so if you decide to go the RP route you will have to purchase the oil individually. plus the oil filters for diesels are 2-3x the cost of the regular filters for most sedans so di talaga sya masama sa 2100.
    mazdamazda, glad to hear that bro!
    s_quilicot, yup mazdamazda either has his work done with us or in speedlab ata.
    Si 06, the mazda needs the motorcraft filter. you can provide it yourself and we can do the rest of the work. we will just charge you for the consumed oil and labor.
    #37
    sir migs
    yesterday nasa LAcars ako and may nakasabay akong civic sa tint Room,
    i noticed na may speedyfix and RP sticker sa rear window, i asked the owner and sabi niya jan daw siya pagawa sa shop nyo and he's using RP oil.
    he says ok na ok daw yung RP, much smoother ride, he saves a lot on gas and lumakas daw hatak. so its enough for me na jan na ako mag PMS ..
    ask ko lang po pasok ba sa 2100 promo ang altis? and how much atf for altis (RP syntheic)..n
    #38
    can anybody explain to me what is the 5w and 30 in the oil means? anung diffecrence of the #w and 30,40,50 in the oil ..
    TIA
    Jun 2006
    #39
    TIA
    the "w" means winter. So for 5w30 it means that its a thin oil that will easily flow at cold temps. Think of it as a 5 weight oil that will not thin more than 30 when hot.
    here's a link to valvoline's explanation http://www.valvoline.com/carcare/art...=ccr20040601ov
    #40
    thanks sir .. sure it helps .. hehehe
MOTUL or Royal Purple?
