glad you like the oilthanks for using it!
Sir Migs,
Pwede ba sa inyo change oil ng Mazda 3, ano recommended oil viscosity nyo dito?
Magkano papalit ng oil pan gasket ng Mitsubishi Adventure Diesel.
Thanks
yup, we normally use either the 5w30 or 10w30 oil for the mazda 3.
for quotations you can call the shop. the number is in my sig.
Ok. Wait ko na lang mag 10k sa odo, mga 9.5k na kasi.
Pag nagpalit ba ng oil pan gasket, palit uli ng engine oil?
Sir Migs,
Ano pa dapat pagawa sa Mazda 3 pwera sa Change Oil , may package ba kayo para sa 10k PMS? Pina PMS ko na kasi ito para sa 10k pero 6K pa lang noon sa odo(6mos). Sabi pinalitan engine oil na synthetic pero parang malapot na ngayon di ko sure kong pinalitan talaga nila o ibang oil ang inilagay.
Thanks
for the 10k pms, it's normally just sparkplugs, air filter and oil. you can use a 5w30 or 10w30 for your engine oil
you can call the shop for a quotation, just specify whether it's the 1.6 or 2.0 engine.
sir speedyfix,
sir vios 06 1.5 gamit ko,currently using castrol GTX 20w50,malapit na ako PMS 30KM..ano po recommended nyo na grade ng RP oil...at magkano po kapag vios...sir ask ko din po kung your shop do PMS ng katulad po sa toyota...magkano po charge...ano po ba mga dapat gawin sa 30KM PMS thanks po...sorry ot po ata...
Just bought last Feb sa speedyfix for my adventure diesel and kami nalang ng brother ko ang nagpalit. After mag change oil, alng laki ng tinahimik ng engine at lakas humatak. Ibang iba sa mga ordinaring synthetic oil. 6 liters ang nilagay namin pero 7 ang binili kaya may reserba akong 1 liter. Ask ko po, ilang kilometers b4 ako magpalit uli ng langis? Thanks!
vrfidel, masyado malapot yung gamit mo. you should be using a 10w30 oil for your car. pasok naman yan sa promo which is on my sig. yes we can do the service. call me nalang or the shop for an estimate.
kuwatog007, good to hear you're happy with it. on diesels i'd go with a slightly shorter interval siguro. 7500-8k kms since it's such a dirty process.![]()
oops. my mistake.
going back to the topic...
is there a significant or glaring difference if I changed the RP oil rating from 10w-40 to 5w-40, that your shop provided for when I had my PMS 6 months ago?
The leftover of about half quart from the change oil I had has already been loaded to my ride.
sir speedyfix i want to try royal purple engine oil , what oil viscosity do you recommend for these cars?
1. bmw e-34 body 525i (m20 engine)
2. 4efte turbo engine (came from toyota glanza / toyota starlet gt)
3. toyota corolla gli (1998 lovelife body , stock engine)
4. honda crv 2007 model (4x2)
5. honda city 2004 (1.3 idsi)
6. honda lxi 1996 (1.5 stock engine)
1. bmw e-34 body 525i (m20 engine) - 10w40
2. 4efte turbo engine (came from toyota glanza / toyota starlet gt) - 20w50
3. toyota corolla gli (1998 lovelife body , stock engine) - 10w40
4. honda crv 2007 model (4x2) - 5w30 or 10w30
5. honda city 2004 (1.3 idsi) - 5w30 or 10w30
6. honda lxi 1996 (1.5 stock engine) - 10w40
what do you mean online? we don't ship RP oils... you can contact Al at 09175266973, he might be able to ship for you.
