Results 6,121 to 6,130 of 6542
August 1st, 2020 03:59 PM #6121
Kulang yang 4 quarts, turbo cars require more oil than NA engines. My old Fiesta 1.0L Ecoboost requires 4.5L (nearly 5 quarts) of oil. What more of the 1.5L Ecoboost?
The ASX has a 2.0L NA engine needs 4.5L of oil conpared the FXT (2.0L turbo) needs 5.5L (6 quarts) of oil.
Sent from my iPhone using TapatalkLast edited by Egan101; August 1st, 2020 at 04:02 PM.
August 1st, 2020 04:05 PM #6122
August 1st, 2020 04:07 PM #6123
- Jun 2011
- 1,081
August 1st, 2020 04:25 PM #6124
August 1st, 2020 04:39 PM #6125
August 1st, 2020 04:45 PM #6126
August 1st, 2020 05:02 PM #6127
September 13th, 2020 03:21 PM #6128
been using motul htech 10w40 for my 1997 honda civic paired with vic oil filter(809). last change oil was april 2019 as per records. oil is at 8k+ mileage. usually within 1yr hindi ko ma reach ung 5k so tingin ko hindi sulit ung oil. just recently lang nagagamit oto ng daily dahil sa pandemic kaya lampas 5k na.
im planning to change my oil soon, hopefully kung masagad ko pa ng 10k mileage.
anong magandang oil na 10w40 na mas mura sa motul? semi or synthetic?
ang tinitignan ko sa ngayon is caltex havoline 10w40 (gray container) and ung repsol elite injection/multivalvulas 10w40.
planning to use better oil filters (baldwin 1402, js asakashi c809j, and wix altho hindi ko alam ano compatible na code)
September 13th, 2020 03:32 PM #6129
September 13th, 2020 04:01 PM #6130
high idle RPM at engine start
