Page 521 of 658 FirstFirst ... 421471511517518519520521522523524525531571621 ... LastLast
Results 5,201 to 5,210 of 6580
    Aug 2012
    #5201
    grp3+
    I'm thinking if mag-HX7 na lang. Change oil every 12 months.
    Sent from my ASUS_X00DDA using Tapatalk
    which vehicle? oil capacity?
    Oct 2005
    #5203
    any feedback sa Shell hx7 5w-40? gagamitin ko para sa Honda jazz 2009 39k mileage. Currently gamit ko ngayon Honda Vtec lev Fully Syn 5w-40. mas mura kasi sa shell kaya gusto ko try.. Thanks
    Feb 2014
    #5204
    Quote Originally Posted by toast View Post
    mura hanap mo? i have a honda city w/ 140,000 kms. i've used the same honda (idemitsu) mineral oil since day 1. i didn't bother to use anything else
    up to now it doesn't burn oil. wala din usok. runs smooth. i have absolutely no reason to spend more on fully-synthetic
    its good.. but far from fs oils. that vtec fs will last longer..
    #5206
    mobil1 new life 0w40
    best oil in the business. even ceratec cant improve it🤣. found a supplier 6000/12liters. imported from france
    ceratec works on less capable oils...
    Ceratec Liqui Moly How well the oil additive protect the engine? 100
    Can i get a lead sir? Interested with the mobil
    Quote Originally Posted by timykoo View Post
    european market area ako...
    locally look for dexos1 or acea a5b5. very good protection for gas applications.
    Dec 2013
    #5208
    Nearing 130,000 km na si monty. Due for change oil na naman. Last oil used was mobil delvac mx 15w-40 + bd28 combo. Naisipan ko tingnan specs ni Delo 400 MGX at naicompare sa Delo 400 multigrade, mas mataas pala TBN at SAPS ni Delo 400 multigrade. Higher means better?
    Quote Originally Posted by Geronimo Valino View Post
    higher tbn yes
    low saps benefits the dpf... but your vehicle probably doesnt have a dpf.
    12×1liter 3000pesos equivalent
    good for everest and rangers 😁
Mineral , semi synthetic or fully synthetic?
