Results 5,241 to 5,250 of 6585
- Jun 2017
- 32
December 20th, 2017 12:20 PM #5241Hello mga masters! Ask lang sana ako kung may nakasubok o gumagamit ng Mitasu Japan FS Oil (5w-40)?
Stageone in E-rod Ave QC ito ang ginagamit na oil. Below is their tune up package.
- Change oil (5w-40) FS Mitasu Japan
- Twin Tip Denso Spark plugs
- Throttle Body cleaning
- Intake manifold cleaning
- Valve tappet adjustment
- Timing
I want to avail their service sana for my Jazz 2010 with 62K mileage and I'm the 2nd owner.
Okay ba yung package nila mga sir?
- Feb 2015
- 633
December 20th, 2017 12:36 PM #5242
- Jun 2017
- 32
December 20th, 2017 01:07 PM #5243Thanks sir makelovenotwar
Repost and edited with price.
Stageone in E-rod Ave QC ito ang ginagamit na oil. Below is their tune up package for P4,800.
- Timing
December 20th, 2017 02:44 PM #5244
decent price. what about your transmission fluid?
- Jun 2017
- 32
December 20th, 2017 03:44 PM #5245
December 20th, 2017 03:48 PM #5246
top up lng? no atf replacement since 2010?
- Jun 2017
- 32
December 20th, 2017 04:56 PM #5247Yun ang hindi ko alam sir StockEngine. 2nd owner kasi ako.
I'll include na din siguro yung atf pag nagpa maintenance ako or maybe ipa-check ko na din kung kailangan ko na magpalit ng atf.
Sorry mga sir kung off topic... Thanks...
December 20th, 2017 04:58 PM #5248
Can't comment on the cost, but I was just thinking do those spark plugs match your car? Also, do you need your valve tappets adjusted? Di ba to adjust it you have to open the top cover? Kasi if it does not need adjustment baka pagsimulan pa ng leak ang pagbaklas kabit ng cover mo. Tina timing pa ba ang new models?
Yung ATF recommended to be changed at 40k or every 2 years, I'm running 4 years and 58k and had my ATF changed 2x na.
Add: nag reply ka na pala, to be sure, I would suggest you prioritize change of your ATF asap, alagaan mo ang tranny mo, use only Honda Genuine prescribed ATF.
December 20th, 2017 05:07 PM #5249
change the atf. it only costs a few thousands. if the transmission fails. madugo
- Jun 2017
- 32
December 20th, 2017 06:05 PM #5250Yes sir StockEngine and sir Papi Smith, replace ko na atf ko sa next maintenance ko. Thank you
When it comes to ATF, DW-1 or Z1?
I'll check na din yung atf na ginamit ko for top up pag uwi ko.
Sir Papi smith, no idea sir on adjusting the valve tappets or kung kailangan na i-adjust. Newbie problem.
or remove ko na lang yung valve tappets adjustment sa package then retain the rest?
Balak ko nga sana, bumili na lang ng Honda FS 0w-20 or Motul H-Tech 100 Engine Oil FS then sa talyer ako magpa-change oil and shell naman for tune up.
Mas okay kaya kung ganun na lang gawin ko mga sir?
