Results 5,641 to 5,650 of 6585
November 28th, 2018 02:58 PM #5641
I use Zic X7 5w30 API SN/ILSAC-GF5 on my Forester XT. I have used it also on my Fiesta Ecoboost. Maybe that will change your views about it. Subaru and Ford have stricter oil requirements on their turbo engines compared to the usual NA engines of Honda or Toyota.
Oks naman, no difference with other oils I have used. I will use Zic again on my next oil change. Maybe the X9 for a change.
- Jan 2011
- 141
November 28th, 2018 03:12 PM #5642
November 28th, 2018 03:26 PM #5643
November 28th, 2018 03:38 PM #5644
December 7th, 2018 07:11 PM #5645
Ilan na ba yung sulfur levels ng diesel dito sa pinas? < 50ppm sulfur o Euro IV standard na ba? Mukang ayoko pa gamitan ng CJ4 or CK-4 oil yung forty ko pero parang gusto ko itry yung Amsoil Signature series 5w30 na CK-4. Kaso CJ-4 oils pataas kelangan ultra low sulfur fuel unless gusto mo mahati yung rated life ng oil mo due to high sulfur levels.
Naka Mobil Delvac 1 5w-40 (CI-4 plus) ako ngayon sa Forty 2.5 (2kd-ftv), with a Donaldson P550335 oil filter.
December 7th, 2018 07:14 PM #5646
December 7th, 2018 07:15 PM #5647
Yup. Naiisip ko sayang naman yung heavy duty filters pag short lang OCI mo. So why not go all the way and use a top of the line Synthetic na Group IV / PAO / Esther based over conventional GRPIII/II oils and go for 1 year OCIs.
It seems more sensible, except during the times when I get stuck in heavy traffic I rethink of my OCIs intervals... "severe service" ika nga.
So currently i'm on the Delvac which is has very low wear numbers sa UOAs on other forums. Pero ayoko lang maingay, so I was thinking of a 30 weight oil to run next time.
- Feb 2008
- 903
December 28th, 2018 06:41 AM #5648I was able to purchase a second hand 2016 Fortuner 2.4L G Diesel A/T and ang sabi ng original owner ay last oil change nya is fully synthetic sa casa and the next oil change is after 10,000km na... I want to continue using that fully synthetic oil, but not in the casa since by its next PMS out of warranty na sya. Question ko lang is ano ba yung oil viscosity ng Fully Synthetic for a diesel engine? What about young semi-synthetic ano ang viscosity? Been checking the manual but I cannot figure out which is the full synthetic from the semi, and from the mineral oil... noob here...
December 28th, 2018 06:52 AM #5649
December 28th, 2018 11:29 AM #5650
Check first if the engine is leaking oil (thin oil will drain fast so its not beneficial for a leaking engine)
If not leaking the highest Cx rating is the best and the thinnest oil will be the best for your engine
Since you opted for fully synthetic then get fully synthetic labeled oil u can find
Sent from my SM-G532G using Tapatalk
Yung extra AUX Fan is useful sa mga naka montero. Mag improve daw yung AC system since may extra...
