Hey guys, any feedback on Royal Purple Oil? It seems to be in the same price range as Motul H100. I wonder, does it give the same protection, and performance as the similarly priced Motul? And would there be Royal Purple's for diesel?
Royal Purple is good quality oil. Check mo itong thread: http://tsikot.yehey.com/forums/showthread.php?t=42843
Eto naman website nila: http://www.royalpurple.com/
They specifically recommend the 15w40 for diesel.
recently used royal purple for my matrix crdi here... like any other oils out there so far okay naman...
kay SpeedyFix Shaw ka kumuha ng Royaltru Orange...este, Royal Purple pala...![]()
yup the 15w40 is diesel rated. so is the 10w40 actually pero better to use the 15w40.
chuaed, maling kulay yun bro! hahahaha!![]()
based dito sa test ibig ba sabihin eh mas maraming napasang tests yun 10W-40 compare sa 10W-30? so mas maganda ang 15W-40 dahil mas marming tests na pumasa?
royal purple motor oil test
Multi-Grade Oils — Typical Properts1, Part 2
SAE GRADE / API SERVICE ASTM Tests
10W30 SL
10W40 CF-4,CG-4,CI-4/SL
15W40 CF-4, CG-4,CH-4,CI-4/SL,CI-4 PLUS
some of the newer tests encompass a whole lot of other things din. basic rule of thumb is use the viscosity that is recommended by the engine though.
Wow! Nice read. Thanks for the inputs guys. This looks like a better option![]()
I'm actually considering this one. I've been to Mobil1 then Motul H100 .. and now Royal Purple.
Last edited by simplicity; November 6th, 2007 at 03:13 PM. Reason: from RP -> Royal Purple
brods, ano bang price range nitong royal purple? i just want to try and feel the difference.
Royal Purple has a diesel rated oil? Matignan nga...Superautobacs alam ko marami RP bottles but not much on diesel![]()
IMm29, glad you think so
wrcastro_ph, parang nadaanan na namin lahat nun ah. hehe! RP has the most comprehensive lineup of viscosities to choose from which is why it's pretty impressive.
simplicity, you're best off using the 10w40. yup we have it and pwede yan viscosity sa promo.
snowbound, RP syn oil is 440/liter, RP XPR racing oil 850/lit, syn ATF 650/lit, syn gear oils 700/lit.
mbeige, yup meron. look for the 15w40 viscosity oil. complete API certification for diesel engines![]()
don't worry about it broanytime you're ready, we'll have stocks naman
i just recently chaged oil. from havoline energy to mobil1 now RP.
just like any change oil, gumanda takbo. pero may isa akong napansin.... ang baba ng temp ng makina! considering 2.0 engine ko.
gas consumption, di ko pa natetest. di pa ko ulit nagpa gas eh. will give feedback pag nakuha ko na data. price wise, mas mura sya sa mobil1!![]()
nagtataka ako bat kaya mura change oil sa mga gas stations like shell..wala pa ata 1k sabi nung kasama ko na nagpachange oil.libre na daw labor and kasama na filter
