Results 1 to 10 of 18
- Aug 2008
- 19
August 1st, 2009 02:33 AM #1i had this problem for quite sometime now..every morning or kapag malamig yung engine mababa yung idle ko pag inistart usually around 600-700rpm although hindi naman namamatayan but i need to step on the gas pedal para tumaas ng onti yung rpm ko but before naman pag cold start nasa 1.1k-1.2krpm ko then baba after a minute or two kapag umandar na. now baliktad kapag umandar nako ng lets say 500meters ayun tataas yung idle ko ng 1-1.1krpm then after ilang kms na tinakbo ko magiging normal na yung idle ko for 800-900rpm. ano kaya possibe na problema? any parts to check?
TIA!
August 1st, 2009 03:36 AM #2
You did not say that the vehicle is carbureted or fuel injected. If it has a carburetor, this might be the problem. If you have an automatic choke, check to see that it does not stay closed for too long. common problem on a dirty carb.
When the motor is cold, it will start right up, but will lump at idle and feel rough because the choke provides a too rich a mixture and overloads the engine to the point where it wants to run rough, almost to the point of stalling. Once the auto choke begins to come open it smooths out.
Check the choke. I'm not saying this is the problem, but it sounds so much like the problem of others.
- Jul 2009
- 23
August 3rd, 2009 06:56 PM #3ganyan itong mazda 323 ko mababa ang idle kapag umaga or malamig ang makina pero habang umiinit tumataas na ang idle hanggang sa marating na ang normal idle.. siguro nga yong choke nya kasi di na gumagana pero ok lang yon sakin..
- Jan 2009
- 123
August 4th, 2009 10:25 AM #4
- Jan 2005
- 445
August 5th, 2009 12:54 PM #5tama si v6, kung carb yan, ung choke mo problema, kc un ang nagbibigay ng mas maraming gas when temp is low.
- Aug 2008
- 19
August 7th, 2009 04:42 AM #6sorry for that btw, my car is corona exsior. dont know the main culprit though. thanks for your input guys!
- Oct 2005
- 64
August 8th, 2009 12:43 AM #7corona exsior with a 3SFE engine. EFI yan and cold start is controlled by the idle speed control valve. baka madumi na kaya stuck na on low idle. just have it cleaned using carb cleaner,
- Mar 2009
- 26
August 19th, 2009 12:56 PM #8Ang ginawa ko hinigpitan ko ang cold idle up screw of carb para tumaas ang cold idle. Ok na sya ngayon, isang click lang pagcold start.
- Aug 2009
- 1
August 20th, 2009 03:29 PM #9ganyan dn un honda hatch ko dati.b16 engine kpg umaga ayaw mg hi rpm. tpos pinalitan ko un choke nya. nka pwesto un sa baba ng trotle body.malamang cra na un syo.hndi na cya bumubukas kya mababa lgi idle kpg unang start sa umaga.
August 20th, 2009 04:45 PM #10
This might be far fetched but I might as well mention it. This symptom showed up on our Lancer GLXi more than a decade ago. Prior to this, a mechanic removed the thermostat (due to it being stucked up closed). When the engine is cold, you really have to step on the gas pedal to keep the engine from stalling. You have to do this for several minutes because without the thermostat, it takes longer for the engine to warm up and the RPM to stabilize. Once the engine has warmed up, everything remains normal until the next cold start. Putting in a new thermostat solved the problem.
I also prefer silver. hindi halata na madumi na and some imperfections like faded color and slight...
