Results 1 to 20 of 21
    Ang ginawa ko hinigpitan ko ang cold idle up screw of carb para tumaas ang cold idle. Ok na sya ngayon, isang click lang pagcold start.
    Alin po ba dun yung cold idle screw? yung nsa tabi ng choke? 4 kc yata yung pwedeng iadjust sa carb eh, yung idle, yung sa may aircon, tpos air/fuel, then parang meron pa sa malapit sa auto -choke. tia
    Aug 2009
    ganyan dn un honda hatch ko dati.b16 engine kpg umaga ayaw mg hi rpm. tpos pinalitan ko un choke nya. nka pwesto un sa baba ng trotle body.malamang cra na un syo.hndi na cya bumubukas kya mababa lgi idle kpg unang start sa umaga.
    Jan 2009
    This might be far fetched but I might as well mention it. This symptom showed up on our Lancer GLXi more than a decade ago. Prior to this, a mechanic removed the thermostat (due to it being stucked up closed). When the engine is cold, you really have to step on the gas pedal to keep the engine from stalling. You have to do this for several minutes because without the thermostat, it takes longer for the engine to warm up and the RPM to stabilize. Once the engine has warmed up, everything remains normal until the next cold start. Putting in a new thermostat solved the problem.
    If your engine is EFI .How long did you clean your MAF Sensor, IACV idle air control valve , Throttle body for long time carbon build up. This is also part of basic maintanance to make your idle in proper order. Just my suggestion.
    Aug 2008
    i already cleaned up my TB using carb cleaner pero ganon pa din, re: map sensor medyo tunaw na yung lower part.
    Oct 2005
    Quote Originally Posted by Xer0923 View Post
    pati yun ISCV bugahan mo din ng carb cleaner. yun sensor safe dapat.
    Aug 2008
    Quote Originally Posted by badtoy View Post
    yun din sabi sakin bro pati yung iscv, kaso kelangan pa i-dismantle di kaya diy.
    Apr 2024
    Maybe thermostat stuck open engine get warm not that fast
    Quote Originally Posted by Rjmar View Post
    yes, this is a possibility.
    Jan 2009
    In our case, the thermostat was removed. But yes, if the thermostat is stuck open, it might show the same symptom. Does it take very long for the temp needle to get to operating temp?
    Jan 2009
    Quote Originally Posted by simarun View Post
    Ang sa Lancer na carbureted, ang cold idle up screw ay malapit sa dulo ng throttle cable, malapit sa auto-choke. Ang ulo ng screw ay nakaharap sa firewall. Ang pagpataas ng cold idle ay ang paghigpit ng kaunti ng screw.
low idling during cold start
