Page 1 of 2 12 LastLast
Results 1 to 20 of 49
    My Toyota Fortuner model 2016 manual does not show when to clean the MAF sensor. So, when is it time to do the cleaning? What are its benefits?
    Aug 2017
    Quote Originally Posted by attyallanlatras View Post
    I clean my GrabCars' MAF every 6mos... Including throttle BODY (TB) .
    Benefits :
    A) Better FC, lean air-fuel mix
    B) Smoother idling
    C) Smoother accelerator pedal (magaan, hindi maganit... TB related)
    Quote Originally Posted by SidCoronel View Post
    Benefits :
    B) Smoother idling
    how often do you change the air filters?
    Aug 2017
    Engine air filter... Every 6mos
    Cabin air filter... Every month
    Note that my cars are GrabCars...change not clean...
    Average 200kms per day
    Aug 2009
    Masarap siguro sumakay sa units ni boss.. palagi sariwa buga ng aircon
    Aug 2017
    Quote Originally Posted by Sleepcare View Post
    Thanks, yes indeed. I'm a serious business owner / car hobbyist
    Apr 2012
    Benefits :
    B) Smoother idling
    you DIY the cleaning of the throttle body or in a shop? how about the intake manifold, have you tried cleaning it too?
    May 2019
    DIY the TB by using an old rug, tb cleaner and a toothbrush.
    Change the air filter every year, I just vacuum mine and reuse it. Then change every other year.
    Clean MAF sensor, maybe every year or two. It depends how often you drive the car or if you notice any change in fc and or idling.
    Quote Originally Posted by Wave24/7 View Post
    Sorry noob here, what is FC?
    fc.
    fuel consumption.
    usually measured in km/li, but further qualified as to type of traffic, i.e., fast highway or crawling edsa, as well as payload, i.e., solo, twosome, or fully loaded with kitchen sink.
    honga. many acronyms...
    Anong brand ng car po ito, at kung madaling kalasin yung TB?
    Yung sa Ertiga kasi they charge 1.2k for TB cleaning, parang mahal?
    actually mura na yan 1.2k for TB cleaning. sa altis club 4k singil nila, tapos reprogram daw ECU para mawala erratic idling daw after TB cleaning. gusto ko sabihin DUH, normal yun at mawawala naman after ecu "relearn"
    Aug 2017
    Ano mas mura... 1.2k TB Cleaning or 1 bottle of Johnny black?
    Aug 2017
    It is detrimental to just clean engine air filters of turbocharged engines... It's the single most inexpensive way to take care of your turbocharger
    Aug 2017
    Aug 2017
    MUkhang effective yan ah.
    It's a bit pricey pero mukhang ok.
    Btw, any tips to clean the maf sensor?
    1) Don't stare hard on the MAF... it might break
    2) Use a CRC MAF cleaner, don't be cheap... The MAF sensor is expensive
    3) 10-15 1sec bursts per CRC instruction
    Pretty straight forward lang MAF cleaning ... Dami sa Youtube
    Apr 2012
    madali lang yung maf sensor bro, unscrew lang then spray ng maf cleaner. contact cleaner nagamit ko ok din. i even used cotton buds with IPA dati, ok din naman, wala naman masyado dumi kaya kahit spray lang ng cleaner. careful lang dun sa sensor probe na hindi magalaw o madamage.
    its the throttle body and the intake manifold that i am tempted to clean but hindi kaya ng "baklas-kalikot skills" ko kahit may tools ako[emoji2960][emoji16] may mga sensors na nakakabit mahirap na. egr kaya ko, ako naglilinis dati. wala na gunk since naka blanking kaya di ko na binubuksan[emoji846]
    Apr 2012
    DIY... If you wanna clean your entire intake system try Revive...
    okay, thanks. looks easy and convenient[emoji108]
    Apr 2008
When should the MAF sensor be cleaned?
