Originally Posted by Egan101 a few minutes after the blue light turned off. When the blue light indicator turns off, it usually means the engine (coolant) temperature has normalized but the engine oil is still not up to optimal temperature ...
View Tag Cloud
Buti nalang hindi binintang yung kotse since hindi naman siya monterosport. It would be different...
When was the last time you changed them? If it's been a while, I suggest following your mechanic's...
My car's axle boot is leaking and the mechanic recommended to replace all (inner and outer). Kasi...
Have good situational awareness. But even then, you cannot anticipate everything. When it's your...
with this incident I will be now more careful in going places wherein there is no concrete barrier...
Yes, it's been established that the root cause was driver error. However, as with any...
In an ideal world, sure. Sa US, the standard they use it seems at terminal entrances and high...
Enter your email address:
Delivered by FeedBurner
