Results 21 to 28 of 28
October 29th, 2008 08:20 AM #21
sir pag ganyan dalin mo na lang po sa technician.. ksi may function check gagawin dyan kung sa battery or alternator or sa starter kung sa amature assy or sa solinoid switch nya.. try nyo po muna pa charge yung battery para madal lng po dun.. or padeliver na lng po .. tnx
- Oct 2008
- 469
October 29th, 2008 12:56 PM #22Mga sir, Update ko lang po. Pina-Charge ko na Batt. Diagnose nila, mahina na nga batt ko po. they charge it for 2hrs. nung kinabit ko na, one click nalang start na agad at mukhang medyo lumakas battery ngayun. Mas maganda po ba kung dadalhin ko po talaga sa electrician para ma check alternator and starter? O, talagang battery lang talaga problem?? Maraming Salamat po sa replies nyo.
October 30th, 2008 12:32 PM #23
just got my motolite enduro 2sm last month. it costs Php3,300 less P400 kung i-trade in mo ang old battery mo. kasama check-up at succeeding monthly check-ups sa services nung kinunan ko. ma-void din kasi ang warranty kung may defect ang electricals mo e.g. alternator, regulator, etc.
kahit umiilaw at may busina, basta less than 12 volts, baka hindi na mag-start. at madiskarga lalo sa kaka re-start mo, FYI. better palit ka ng new battery kesa itirik ka pa sa daan.
- Jul 2007
- 16
October 30th, 2008 04:47 PM #24sir, it's better patingtin mo pa din sa electrician yung sasakyan. so they can test the battery kung kumakarga ng maayos. malamang kasi baka may problema ulit alternator mo kasi nga na diskarga ka. which means your battery is not charging. mauubos din ulit yan power ng battery mo. had this problem a hundred times before. medyo na master ko na. hehehe
- May 2008
- 21
October 30th, 2008 05:30 PM #25Sir,
Pwede malaman kung san mo nabili ang battery mo. Sa Sta Rosa po ba? Baka may Manila branch yan. Same specs ang akin pero mas mataas ang presyo na nakuha ko. I ended up paying Php3,180 kahit nag trade-in ng lumang battery at Php500.00. Although earlier ko binili. Pababa ba o pataas dapat ang presyo?
- Oct 2008
- 469
October 30th, 2008 11:43 PM #26Sige po mga experts, dalhin ko nalang sa electrical shop by monday or tuesday. Anu po ba pinaka mura na battery ngayon na 12V maintenance free??
November 5th, 2008 08:00 PM #27
November 6th, 2008 12:18 PM #28
Thanks, I checked them out pero walang Michelin Ang laki ng difference ng price sa Jiga....
Finding the Best Tire for You
