Results 1 to 10 of 14
- Aug 2008
- 38
August 26th, 2008 02:11 PM #1Good Day po! newbee in the forum and first time to owned a car.
Bought a second hand car last month toyota glxi 94 model. Ang problem po ay tuwing mag start ako after 3-5 mins may white smoke na lumalabas after 3-4 rev wala na sya at kahit umaandar na ko wala na usok. Ganda naman takbo at hatak. Ang isa pang problema, kapag medyo matagala na umaandar ot tumatakbo pag na stop ako sa trffic na nginginig na makina, at tuwing nagiikot na ako sa parking lot nanginginig makina. kaya pinapatay ko aircon, pero andun parin ang nginig. Kapag umandar ka naman ng medyo mabilis at himinto ka ulet, mayamaya andya na ulet ang nginig. Then isa pa po, yung radiator fan eh umaandar na kapag on mo palang sasakyan, hindi ko sya napansin nung binili ko. kasi sobrang ingay dun sakalye nila. pls, help! wala kao alam na mekaniko na matino pa. hehehe.
- Sep 2007
- 215
August 26th, 2008 06:46 PM #2you need a top overhaul ... white smoke means your engine is eating oil ... that is why there is white smoke .....
for the vibration i think your engine support need to be replace .....
yung auxiliary fan mo naman ay nakarekta ... meaning tinangal yung thermostat ... medyo maraming sira yung car mo ... not a good buy yan ang mahirap pag second hand ...
toyota naman yung car mo ndi naman mahirap maghanap ng mga parts ... need help call me tom at 8:30 am at my store
7120115
regy
hope this help have a nice day
THE AUTO SPECIALIST
- Mar 2006
- 607
August 26th, 2008 08:27 PM #3under observation muna
check mo yung coolant level , after a week kung bumababa at walang leak cylinder head gasket or cyl head cracked
white smoke means you're burning coolant
magtanong ka sa mga kaibigan mo na may kotse kung saan okey magpagawa
satisfied customers always bring customers with them
- Aug 2008
- 38
August 27th, 2008 10:00 AM #4tks sa reply *banawe and *bambino
na chk ko naman yung sa coolant hinde naman sya nababawasan.
...may bomba palang nakakabit sa kotse na nabili ko haha.waaaaaa.
anyway yung nginig naman eh nagyayari kapag matagal na nagamit.chk ko mamaya yung idling rpm.
salamat po sa reply at sa mga magrereply pa! hehhe
August 28th, 2008 09:04 AM #5
relax lang bro. sometimes OA reaction natin sa loved cars natin. taga-san ka ba? marami namang trusted shops dito. the white smoke can just be moisture inside the engine kung nawawala naman when normal na operating temp engine mo. check oil level regularly. the nginig can be engine supports or too low idle setting.
- Jan 2008
- 380
August 28th, 2008 03:07 PM #6Oo nga relax lang, palagay ko di kailangan ng overhaul nyan, kulang lang yan sa karinyo. Linisin mo muna yung IAC valve, pati na rin injectors, parang kasing kinakapos pag biglaan ang break, hindi smooth yung power deceleration. Yung baradong PCV system may also result to these complaints.
Nangyari na sa akin yan, yun ang mga ginawa sa casa, pero nilinis na rin yung buong intake manifold.
August 28th, 2008 07:35 PM #7
yup, easy lang muna. if i were you, dalhin mo sa isang reliable shop that can assess yung problem mo. or pwede rin sa casa (pa check and estimate mo) libre doon. then pagawa mo sa iba.
dati kong na-experienced yung white smoke from idle then arangkada (naku, super white) as in less than a month top up ako ng 1liter na oil. na-resolved sya nung pinalitan yung valve oil seals. madugo yung gastos pero peace of mind for me. hth
August 29th, 2008 02:20 AM #9
White smoke indicates that coolant is entering the combustion chamber - have a "leakdown test" done to determine which if any cylinders has a headgasket leak.
When pressure is sent into the combustion chamber at top dead center - if the coolant level rises inside the radiator then you either have a "blown" headgasket or a crack in a cylinder wall.
- Aug 2008
- 38
August 29th, 2008 12:25 PM #10samalt po sa mga nagreply pa! tks sa palakas ng loob marami ako natutunan kakabasa sa ibat ibang forum. bukas dalhin ko sa casa for chek-up LANG hehehe. Dito lang ako sa c5/mindanao ave./quirino hi way. may tsikoters na nag rekomenda na ng isang shop sa congresional ave. update ko kayo sa mga mangyayare.
mahal ba kung cracked na yung cylinder head? repairable ba ito?
tks ulet po.
Xiaomi E-Car
