Results 11 to 20 of 71
- Nov 2002
- 162
March 10th, 2003 07:07 PM #12sir chieffy,
how much nga pala yang Caltex extended life coolant? pwede ba yan sa accord?
kailangan bang palitan yan or iflush every x number of years?
- Sep 2010
- 23
September 22nd, 2010 10:19 AM #14Hi sirs, I'm a newbie when it comes to cars, I just learned to drive 1 month ago. Ask ko lang, pag long time na water ang ginagamit as radiator fluid, kailangan ko pa ba mag flush before using a real coolant?
September 22nd, 2010 10:32 AM #15
- Jan 2008
- 380
September 22nd, 2010 10:38 AM #16One time nag top ako ng orange coolant sa green coolant, ayun nagkaroon ng gelling.
As a precaution I do not mix two different brands of coolant.
September 28th, 2010 11:07 AM #17
tanong lang mga sir... my vehicle is running without coolant eversince.
do you recommend that i put one na or stick to current na distilled lang nakalagay.
just worried kasi baka magloko if ever maglagay ako and also thinking (pwedeng mali pi ako) na since matagal na sya medyo mas mainit na ang engine nya at kailangan na lagyan ng coolant.
September 28th, 2010 11:48 AM #18
IMO, that'll be fine, as long as you'll still use distilled water, and not tap/mineral water. but if you want to spend for about Php 800 (coolant + distilled water + radiator flushing + labor), then go for it.
- Sep 2010
- 16
September 28th, 2010 12:19 PM #19--------------------------------------------------
good day po Sir....
ask ko lang po Sir bakit po kelangan e "distiiled water" and not "tap/mineral water" ang ilagay para sa radiator...paki educate lang po ako Sir sa kahalagahan ng "distilled water sa ating car radiator...TIA
- Jan 2008
- 380
September 29th, 2010 12:47 PM #20good day po Sir....
^Thanks for the advise guys. Already replaced all.
Rubber boot question (repair or replace)
