Results 1 to 10 of 19
- Apr 2017
- 16
May 16th, 2017 09:02 PM #1Hi,
Bought a second hand fortuner (2005) and thinking of changing the timing belt as the previous owner has not changed it yet. Any idea how much this will cost and which workshop can do this best? Sa may Paranaque area ako nakatira so somewhere dun sa area would be good. Odo reading is at around 85K but not sure if this is original milleage and I think best to change para peace of mind. Salamat.
- Jun 2005
- 3,774
May 16th, 2017 10:07 PM #2Kung gas variant yan, chain type sya. Walang timing belt.
Kung d4d pinapalitan ang timing belt. Kaya naman.yan ng any decent mechanic. Basta maipantay nya lang timing marks before tanggaling timing belt
- Apr 2017
- 16
May 19th, 2017 01:12 PM #4
You can also replace the following:
- T-belt (get original)
- tensioner bearing
- water pump
- serpentine belt
Replace all fluids na rin (differential, ATF, power steering, coolant) para fresh na fresh, and the fuel filter.
I recently inquired for the 2.5 D4d engine (Grandia) at Toyorama in Banawe and was quoted as follows:
ATF - P 441 per L or P 1,300 per gallon (Toyota T IV)
Serpentine Belt - P 1,800
Gear oil (for the differential) - P 260 per LLast edited by vinj; May 19th, 2017 at 01:14 PM.
- Apr 2012
- 3,469
May 19th, 2017 02:14 PM #5
- Apr 2017
- 16
May 20th, 2017 02:39 PM #6Just learned na may promo ang toyota bicutan, not sure kung ganito rin sa ibang dealers but yung price ay 10,500. Kasama labor, replacement ng timing belt, idlers, tensioner at yung camshaft at crankshaft oil seals. I think mura na considering na original and hindi replacement parts...
- Jun 2005
- 3,774
May 20th, 2017 03:12 PM #7^ baka naman labor lang yan, wala pa yung parts replacement
- Apr 2017
- 16
May 20th, 2017 03:55 PM #8
- Apr 2012
- 3,469
May 20th, 2017 04:02 PM #9
- Apr 2017
- 16
May 20th, 2017 07:10 PM #10
Yes, i do think so. Since it's based on the 4th-gen delica/space gear, which in turn shares some of...
Mitsubishi Philippines
