Results 1 to 19 of 19
    Jun 2005
    Kung gas variant yan, chain type sya. Walang timing belt.
    Kung d4d pinapalitan ang timing belt. Kaya naman.yan ng any decent mechanic. Basta maipantay nya lang timing marks before tanggaling timing belt
    Apr 2017
    Quote Originally Posted by sirkosero View Post
    OK, salamat...
    You can also replace the following:
    - T-belt (get original)
    - tensioner bearing
    - water pump
    - serpentine belt
    Replace all fluids na rin (differential, ATF, power steering, coolant) para fresh na fresh, and the fuel filter.
    I recently inquired for the 2.5 D4d engine (Grandia) at Toyorama in Banawe and was quoted as follows:
    ATF - P 441 per L or P 1,300 per gallon (Toyota T IV)
    Serpentine Belt - P 1,800
    Gear oil (for the differential) - P 260 per L
    Apr 2012
    - tensioner bearing
    - water pump
    - serpentine belt
    Kasama pala water pump sa T belt ng Hiace
    Sent from my LG-H818 using Tapatalk
    Apr 2017
    Just learned na may promo ang toyota bicutan, not sure kung ganito rin sa ibang dealers but yung price ay 10,500. Kasama labor, replacement ng timing belt, idlers, tensioner at yung camshaft at crankshaft oil seals. I think mura na considering na original and hindi replacement parts...
    Apr 2012
    Quote Originally Posted by joelsp View Post
    If you DIY how much would it cost?
    Apr 2017
    Yung price ng parts from toyota nasa 10,000 peromalamang mas mura kung hindi sa casa bibilhin. Di ako bihasa to do it myself so did not consider dong it myself.
    May 2009
    hmmmm
    yung pinagtanungan ko na servitek dito sa amin e sabi bando t-belt, tensioner at tensioner bearing ng d4d (innova) e P5,000 (package)....parts lang yun....tapos nasa tipong P100 lang naman ang oil seals per piece (NOK brand)
    Apr 2012
    Quote Originally Posted by miked View Post
    hmmmm
    Ilan ba oil seal ng 2KD? Ano ba talaga mga dapat palitan. May mechanic told me d naman daw dapat palitan ang water pump. Ano ba talaga? Need help
    Feb 2019
    hmmmm
    u can use
    - tensioner bearing
    - water pump
    - serpentine belt Audacity Find My iPhone Origin
Fortuner timing belt change
