Page 6 of 8 FirstFirst ... 2345678 LastLast
Results 101 to 120 of 143
    Dec 2009
    #101
    Mga sir ask ko lang. Sa mga naka starex napa blank nyo ba egr nyo?
    Apr 2011
    #102
    Quote Originally Posted by Stigg ma View Post
    any proof you got there???
    Adventure??? eh mechanical diesel yan eh...
    possible nga sir na kahit mechanical diesel siya mababawasan ang usok because of lower sulfur content of euro IV diesel.
    Nov 2014
    #103
    Sayang maganda sana usapan dito kaya lang english.hehehe..pwede po ba kayo magtagalog. Hehehe
    #104
    Quote Originally Posted by radz15 View Post
    Kung Grand Starex,- yes,- both the TCi and the VGT(EuroIV) engines...
    EuroV engine - CEL issue....
    25.9K:branch:
    Aug 2010
    #105
    Nag Try ako mag pa blank ng egr kay sir Zix888. MOntero 4m41 po ang gamit kong sasakyan
    Pros :
    Faster Response on low- mid rev
    improve fuel Consumption
    no black smoke
    no more egr cleaning
    cons:
    bat di pa ko nag pa blank last 2010.
    next ko ipapablank yung fortuner 2kd ftv
    Pros :
    no black smoke
    cons:
    Nov 2014
    #106
    Tanong ko lang po mga sir, advisable po talaga na mag pa EGR blanking? Hulugan po ang sasakyan ko 5 yrs. Fortuner 2015 po sasakyan ko manual.
    Dec 2009
    #107
    25.9K:branch:
    Eh kung lumang starex sir? 2005 model grx crdi?. Thanks!
    May 2015
    #108
    bago lang ako dito,pwede ko rin mahingi contact ni sir zix interesado din po ako sa egr blanking para sa grx crdi 2005 model starex.maraming salamat po
    May 2015
    #109
    Quote Originally Posted by jnh01 View Post
    Kind Sirs, pa-PM din ng details kay Sir Zix (Address and Tel No). Magpa-blank na din ako ng EGR. Thanks po!
    ako din sirs, i need it maraming salamat po.
    Apr 2015
    #110
    Saan po kaya sa batangas pwede magpa EGR blanking? Badly needed po. Thanks in advance.
    #111
    Same question as above!
    Jan 2008
    #112
    Quote Originally Posted by radler View Post
    there are lots of tutorials on how to blank egr.. it can be done DIY. depends on type of vehicle. egr of kia engines can be difficult due to their egr modules have built in cooler and relatively large unlike with mitsubishi that use just a simple tube to direct exhaust gas to intake manifold
    #113
    Gentlemen, would appreciate if you could share ways to connect with zix for the egr blanking. Thanks
    Jun 2008
    #114
    Quote Originally Posted by blueblaze View Post
    try this bro -
    09174659952
    try this bro -
    09174659952
    #115
    Thanks a lot, Sir lexie!
    Jun 2015
    #116
    Some calls it egr blocking I call delete complete egr removal
    On big engines I usually just disconnect the EGR harness in the morning when engine is cool after it's self ck mode cycle that's if you knew the egr is not sticking yet meaning egr still closing but will trigger ck engine light in most cases it will not cause power derate. Some use programmer and block off plates some just trick the delta p sensor or atmospheric pressure sensor or install new software on ecu
    Never did like the Idea of egr gas or diesel think of it this way you fart then breathing back your on fart egr engine is more expensive to do overhaul than non egr identical engine not because of added parts but egr engine has to survive wear on piston,liners rings etc. I had a truck engine once that was loosing oil pressure after 10000 kilometers due to carbon build up on oil and plugging the filter the piston ring was getting worn yes but after deleting the egr I was able to run truck 25000 Klm without oil filter getting plugged up just to buy some time and it last me 9 months till we did the oh
    I know for sure my engine is stronger and cooler without the egr
    As for the manufacturer developing the egr they don't really have a say its the EPA controlling them. At some point a engine manufacturer actually will reprogram a egr ecm to non egr and sells the block off plates
    Mar 2012
    #117
    I had my monty's (2011 gls v) egr blanked more than a year ago by zix.
    I've been monitoring my FC, both city & highway trips, on my navigation screen & it appears to indicate that it has increased as compared to when it wasn't blanked yet.
    For example, at the nlex yesterday with ave.speed of 100kph, I was only making 11 kms/l. I think I used to make 14kms/l before.
    My ride has 30,000 total kms on the odo.
    For those with blanked egrs, how have your FCs been?
    Mar 2012
    #118
    Added info - I only use unioil for fuel, baldwin filters & full synthetic oil.
    Aug 2013
    #119
    Quote Originally Posted by green eagle View Post
    almost 1 year na din yung sakin bro. si zix din ang gumawa sa Innova. same FC sa city driving pero mas tumipid sa highway. dati highway FC ko 14 km/l, after blanking above 16 km/l na. yung 14 km/l na FC running fully synth oil (toyota) pa yun, yung 16 km/l ngayon, mineral oil (mobil delvac mx) na gamit ko.
    Aug 2015
    #120
    Meron na po ba nagpa egr blanking ng nissan navara np300 nila? Care to share your thoughts/experience? Thinking if I should have mine blocked. Thank you!
EGR blanking / blocking - what is the real deal?
