i had mine cleaned and blanked last week. spent 600 pesos. all I can say is sulit! i can now feel the turbo spooling as early as 1500-1700 rpm
Napablank ko din innova ko na 1st gen. Had black smoke problems before. Nadala ko na sa casa twice. First time, they just cleaned the exhaust system. The second time, they "replaced" the egr daw... Still black smoke after a few months... Visited central diesel in quezon ave...they replaced 2 injectors that according to them has abnormal spray pattern... Spent a fortune... After a few months, black smoke returns.... I brought it back to them... They checked the egr and injectors via obd2 scanner...no faults found... They serviced/cleaned the egr without charge...after more than a month, black smoke returns... I researched in sulit/olx and found someone selling a stainless steel blanking plate. I bought one and had it placed by my suking mechanic...He told me it might be a turbo problem... We install the plate....lo and behold...black smoke gone...meron pag nasa 3-4k rpm pero not as much as before. Dati parang pusit worse than smoke belching buses and jeeps.to guys out there having doubts on egr blanking...it will save you a fortune and lots of hassle like i experienced. If i only knew then...
Had a black smoke problem with my Montero GLX even when it was brand new. Pusit mode starts at around 2.5K RPM. Started using 2T oil as fuel additive. It solved my black smoke problem. Some smoke comes out but at around 3.5-4k RPM. Haven't tried blanking yet but will do after I have the EGR cleaned.![]()
Sa Fortuner din nangyari sakin, namatayan habang traffic.
The same day, Nag check engine din. Tapos piņa check, ko sa casa. Sabi papalit an daw injectors, scv, etc. Worth 150k total lol.
Tapos wala ako pinapalitan and d ako pumayag. After a few kms , normal na ulit. Never na nangyari. Ano ba cause nun sa diesel? Bad diesel Lang?
Mga sir, may egr egr blanking ba lahat ng diesel? Meron kasi kami yung 2000 model na isuzu hilander extreme. Pwede ba yun?
Simple lang sagot jan. Kung may egr ang makina (diesel o gasman yan), pwede siya i-blank. Kung wala, syempre wala kang iba-blank.
So google the engine of your highlander and confirm kung meron egr.
eto meron pala sa tsikot. ni googol ko na hehehe
http://tsikot.com/forums/isuzu-cars-.../index290.html
?[/QUOTE]
