Results 21 to 30 of 143
October 28th, 2013 12:24 AM #21
Doc, it would be great sana if the EGR cooler also acted as a filter to remove all the soot in the exhaust gas before reentry.
Water/alcohol injection is said to lower Nox as well. Almost had one installed but chickened out, I thought it's one more thing to check regularly and worry about.
- Sep 2013
- 26
October 28th, 2013 07:25 AM #22
Sir Otep...
This caught my attention.
If EGR recircs some hot exhaust gases back and simply mixes this with cooled air from the intercooler, parang it negates the whole process. (as shown on the diagram re: turbocharger / intercooler flow)
Question now is do Fortuners and Monteros (or recently released SUV's CRDI's & intercooled) have EGR coolers as standard.
Salamat Sir Otep.
- Apr 2008
- 1,557
October 28th, 2013 07:25 AM #23Dahil sa post mo na ito, sir, mas lalo pa ata akong na convinced na ipa blank ang EGR ko.hehe
But does it still have maintenance kahit blanked na or totally wala na since naka cover na?
- Sep 2013
- 26
October 28th, 2013 07:58 AM #24Sir rna800...
Am having the same dilema.
Baka yung 3 yr old fortuner ko i-blank ko if emission test on rehistro says readings are bad.... out of warranty na din naman na siya.
Can't say the same thing for the newly released Montero though...
I suppose kahit blanked na EGR's proper maintenance pa din dapat, like proper change oil intervals using best available motor oils and filters.
Siguro cleaner diesel fill-ups too... I think there is a thread for euro2 / euro3 / euro4 diesels... pero mula nung meron na euro4 unioil, yun na gamit ko.
Pansin ko as engines (both gas and diesel) become modern the maintenance becomes more delicate coz of the newer gadgets slapped into it... ergo, those gadgets make our rigs run better / faster / SAFER / but sana easier to maintain
At the end of the day, maintenance equates to safety IMHO.
- Apr 2008
- 1,557
October 28th, 2013 11:12 AM #25Pansin ko as engines (both gas and diesel) become modern the maintenance becomes more delicate coz of the newer gadgets slapped into it... ergo, those gadgets make our rigs run better / faster / SAFER / but sana easier to maintain
Oo nga sir, kung ano ano ang sinasalpak nila sa auto para mas gumanda kaso sakit sa ulo pag pumalya lalo pag medyo nagkaka edad na ung sasakyan. Buti ung akin ok pa ung both EGR and SCV ko.
I agree, dapat proper maintenance talaga. I also fill up in Unioil kasi Euro IV sila.
October 28th, 2013 12:50 PM #26
You can check if the monty has one. It looks like a small intercooler. The ranger has one.
Sent from my GT-I9082 using Tapatalk
- Sep 2013
- 26
October 28th, 2013 02:20 PM #27Sir Djerms,
Are you referring to the EGR cooler?
Other Montero owners are saying meron, frankly hindi ko alam kung asan banda sa engine bay, I guess malapit sa turbo so it has to be sa harap ng passenger side.... malamang ganun din sa old Fortuner ko.
Kung meron nga, do these coolers need maintenance too?
Salamat Senyor
October 28th, 2013 02:38 PM #28
The montero sport has an egr cooler. It has no moving parts. Its just a heatsink type device like on car audio amplifiers and pc motherboards. It is on the side of the engine. Afair, it looks like a loaf of bread.
- Sep 2013
- 26
October 28th, 2013 02:52 PM #29
Sir, my case, our trusted mechanic recommends EGR cleaning kahit hindi pa fouled-up sabay check na din ng SCV.
That's what he's been doing to other suking clients.
Sinagad ko 3 yr old Fortuner ko na puro check lng if needed to be cleaned. Nung first 2 years sa Casa, on the 3rd year si trusted mechanic na.
I'll see how emission test results at 21k mileage will be, that may trigger decision to blank or otherwise. Have been learning from comments and replies of fellow forum members. Just have to sift thru details, everything is very enlightening though.... Kudos to "forum-members-in-the-know"
You mentioned "edad ng sasakyan".... one thing worth asking is kahit ba may edad na ang sasakyan pero mababa pa din mileage kasi meron naman karelyebo na ibang sasakyan, nalalaspag ba mga parts / gadgets / emission sensors.... take the case of 3 yr old rig with only 21k mileage.. also I know of a 10 yr old ford escape with less than 60k mileage, still running great, interior & exterior makinis, and i think only the alternator and ac compressor was changed, else puro change oil / filters / spark plugs lang.
- Nov 2009
- 3,509
October 28th, 2013 04:04 PM #30Modern engines will last like old schools but the maintenance is more on the hi-tech and costly side. Hindi tulad ng approach ng old school na pwede re-build. In these days puro assembly na ang pinapalitan.Kung nakita ng casa sa scan tool na may error EGR at outside limits ng tolerance, ang recommendation nila at nasa service manual ay palit buong assembly. Palit assembly then pag nawala ang error, consider it as problem solved. Mas kumikita ang casa sa palit kesa linis, more on man-hours lang ang binabayaran sa linis kaya mostly outside talyer na lang ginagawa. Kung car owner ka at medyo nagtitipid tulad ko at meron naman tools, we'd rather make ways to lengthen service life by doing preventive measures. Kahit nga paglusong sa baha, i think twice nowadays.. Isang buong assembly kasi ang hub and bearing kapag pinalitan.
Now that your vehicle is out of warrenty, here's what you can do to lenghten the engine's life. Take note, without the engine, your vehicle is as good as dead/not fit for the purpose..
Blank the EGR
Delete the cat
PCV Oil catch can
Install water injection and activate it on long trips
Better filters and lubricants
PS. Para mabenta at malagyan ng Euro2 sticker, L300 nowadays have an EGR too. IDK how theyre going to diagnose that, wala namang ECU.lol
And yeah, Yotas 2L/T engines are sturdy, mejo prone lang sa overheating at mausok. I still remember the distinctive sound of 2L, parang isuzu engines may sariling tono.
soy-based wire insulation. 1. cheaper than the petroleum-based plastic insulation. 2....
BYD Philippines
