Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 66
    #21
    Quote Originally Posted by arnarn View Post
    up ko lang to. hirap na maghanap ngayon ng gas stations na nagbebenta ng non-e10 blended gas. sa mga nagkakarga ng e10 sa carb nila, feedback naman jan.
    I use sea oil unleaded almost 2 years . My engine is Toyota 5k so far no problem on my fuel lines what i heard on the rubber hoses. Almost the same in performace compare to other brand .
    #22
    I dont gas up gasolines blended with ethanol for it may damage my engine. Pinapakarga ko na lang XCS Plus which is pure gasoline, para walang problema sa huli. Kahit na may 3 pesos difference ata, okay lang if it will not give me hassles at the end.
    Oct 2005
    #23
    in due time lahat na ng gas puro E10 na. we just need to be more aware of the parts na madadamge such as rubber parts like hoses gaskets and seals, kaya dapat mas frequent ang pagpapacheckup mapa EFi or carb man ang engine.
    Jan 2008
    #24
    Kinaligkig din yung makina ng kotse ko ng makargahan ng Petron E10, shift ako sa Caltex yun nawala. Ewan ko kung palyado yung blend ng Petron E10 pero Caltex na karga ko ngayon. Yung utol ko ganun din parang nagka-malarya daw yung engine nya sa Petron E10.
    O baka nabigla lang yung ECU ng makina. Nakadalawang tanke ako ng Petron E10 bago ako lumipat sa caltex.
    Dec 2008
    #25
    Hi !
    Am using Caltex E10 on my corolla 2000 1.3 carb engine. Been through 2 or 3 tankfuls of their unleaded with E10. So far, no noticeable differences naman as far as engine performance.
    But mas mabilis nauubos ang gas ... less kilometers per liter.
    Will be trying their premium gas on my next visit.
    As far as I know, all unleaded gas available in the market has E10 in it. Na phase out na daw ang non-E10 according to the gas attendants.
    Like what others have said, no choice actually ... hehehe
    #26
    [SIZE="4"]MOD's Note: Multiple Threads Merged[/SIZE]
    #27
    been using e10 on my ae92 carb engine since june 2009. no noticeable performance problems. ang napansin ko lang mas malakas consumo ng gas not like when i was using pure unleaded gas.
    Oct 2005
    #28
    yung 1991 Lite ace namin Walang problema sa E10..
    #29
    i have 97 tamaraw fx 7k. so far wala ako problema sa e10. pansin ko malinis ang exhaust. likewise i dont worry kung sabihin man na pang-efi lang ang e10. like others say, no choice na tayo kundi e10 ang gamitin wag lang ma-implement ang e15 or higher ethanol content. don na tyak magkakaroon ng problema ang mga carb engines. tolerable pa rin naman ang e10 as far as my experience on my 7k. magmula na-tune up ang makina ko ang ganda ng idle at acceleration. dinoble ko (series) ang fuel filter kasi mura lang naman. balak ko gumamit ng platinum o iridium spark plugs kung may budget na. but so far ok pa naman ang ngk na gamit ko ngayon.
    #30
    Kindly help me list all the gasoline brands that doesn't have E10/Ethanol added...
    From what I know for sure:
    Petron XCS
    Total Protec
    May 2005
    #31
    Petron XCS
    Total Protec
    Caltex Gold wala pa ring blend ng ethanol
    Apr 2009
    #32
    Petron XCS
    Total Protec
    Quote Originally Posted by Asus700 View Post
    As of now, I think Petron Blaze nalang ang pure gas. Yung XCS at Gold dito sa amin at sa Metro Manila ay e10-blended na rin.
    Damn, this e10-carb thing begins to be my concern since I now drive a toy car with a carb engine (3k toyota) ...
    It runs in e10 blend and I'm too insensitive to feel the effects since I really don't expect much anymore from the really old engine... Pansin ko lang ang bilis maubos pag e10, pero kahit blaze na puro ang ikarga ko mabilis parin maubos
    #33
    Don't you feel any hesitation when accelerating when using Petron Blaze, bro? I somehow have this feeling that now, Blaze is also ethanol-blended.....
    9505:spam:
    Jul 2003
    #34
    i'm not really bothered by this e10 thing.
    some say up 10% ethanol is fine.
    some say it will affect the engine especially rubber seals etc. (i'm not going to talk about engine performance since i believe it can be taken cared of by tune up).
    examining the path from the tank to combustion chamber (especially on carbed engine) I don't see too many rubber components making contact with the fuel.
    maybe some can shed light on this.
    #35
    Quote Originally Posted by fourtheboys96 View Post
    E10 gasoline ate my car's fuel line and opened a pin sized hole that sprayed gasoline inside the engine bay.
    Scary in that it was a potential fire bomb if I didn't catch it then.
    Jan 2010
    #36
    nagkaproblema din ako sa E10 na yan. dati unleaded lang kinakarga tapos nung medyo paubos na gas ko i dont have a choice kundi mag pa refill sa malapit na gas station which is they sell gas na may E10 na. then after a day nag iba na andar ng sasakyan ko biglang ang sama ng usok tapos nanginginig ang makina tapos tinitirik ako sa daan. bagong linis pa naman yung carburator ko pati yung fuel tank ko. hayzzz hirap talaga gamitin ang E10 sa mga carb engine based on my experience.
    Apr 2008
    #37
    wala naman akong naging problema sa shell E10 para sa EE90 ko na naka 2E carburated engine mahigit 2 years ko nang gamit yan bago pa ito nakarnap.
    yung sinasabi nilang corrosion or limescales lalo na sa carb wala naman nakita nung balkasin ko ang carb ko nung para linisin, yun sa rubber hoses at fuel lines sa carb at sa iba pa na sinasabing magkaka-crack, lolobo or liliit ang butas wala din pati yun sinasabi nilang yung plastic ay puedeng lumutong gaya na lang ng sa fuel filter hindi naman lumutong.
    ang panget lang talaga sa E10 kapag hindi mo ginamit ang kotse mo or pinaandar ang makina mo ng mga ilang araw medyo hard starting sya sa at pag napaandar mo naman may maririnig kang mahinang "ticking sounds" sa valve mo pero nawawala naman kapag uminit na, yan ang napansin ko samantalang nung unleaded lang ang gamit ko kahit hindi ko nagamit ang sasakyan ko ng ilang araw ay one click pa rin at wala kang maririnig na ticking sound sa unang andar ng makina mo.
    Jan 2010
    #38
    add ko lang to FAQ about Fuel Ethanol (Bioethanol) E10hope it helps.
    #39
    I`ve started fueling up ethanol blended gases on my AE101 Corolla.
    Shell Super Unleaded. ;)
    #40
    i think it will work 93 lancer el carb type car ko ok naman tsaka may kakilala ako 90 nissan maxima pinakarga niya may e10 ok naman takbo ng kotse.tsaka halos lahat na ng gas station may halong e10 na.anu pinapakarga mo super premium ba sa shell?
E10 gasoline on carb engines [MERGED THREADS]
