Page 29 of 93 FirstFirst ... 192526272829303132333979 ... LastLast
Results 561 to 580 of 1853
    #561
    maraming salamat sir MrQ5:D will pm tsikoteers po:D
    Aug 2009
    #562
    Quote Originally Posted by MrQ5 View Post
    anu po yung engine nio, baka po CRDi gen3 na yan?
    basta po prior 2007 ang engine good to go na kayo just follow the standard ratio recommendation na 1:200 then bahala pag medyo matagal na kayo na mag-adjust sa ratio.
    Thanks MrQ5 sir. 2003 FM po rig ko with a 4m40 mitsu engine...just in time with the new lowered price of diesel magfull tank na ako with a 450ml dose of 2t..... many thanks po again.
    #563
    napansin ko po a few years ago.. ang uso ay.. bio diesel..
    same po ba sila ng properties ng biodiesel? i mean ito napo ba kapalit.. parang wala napo kasi biodiesels etc etc dito satin ngayon eh..
    thanks
    #564
    Quote Originally Posted by AC View Post
    thanks
    All diesels now are bio diesel, iba iba lang saa blend but i believe 5percent blend na sila now, siguro thy dont advertise it as much na.
    #565
    sir ken... meron po kasi ako isang old box ng bioactiv... a few years old na siya... binili ko sa friend ko na dati pa nagaalok ng biodiesel... and ngayon naglilinis ng bahay.. napulot ko po... seems to work great po kasi.. naalala niyo po yung pajero ko? mausok diba... pinacalibrate ko po yun and pinalitan naman ng filter... ganun padin.. pero nung naglagay po ako bioactiv... nawala po nginig and usok...
    kaya i was thinking kung medyo similar po kaya 2T sa biodiesel...
    1 bottle for every 85liters lang po nilalagay ko.. recomended is 1 bottle 50liters...
    baka the fuel sellers po is not putting in enough.. volume po kasi negosyo nila.. kaya ilan % lang ibawas nila malaki na sigurong pera... i called up some biodiesel sellers... hehe kayalang minimum order is 20t liters:D baka meron po nagbebenta kahit 1 drum lang?
    Sep 2004
    #566
    guys is 2t safe to use with total low sulfur diesel?
    Jan 2008
    #567
    Quote Originally Posted by vyn300d View Post
    yep, filled my ride with it yesterday.
    and dont be confused with the low sulfur thing, its still euro2 diesel.
    Dec 2007
    #568
    The whole reason to use the 2T is because the diesel fuel now contains to low of a sulfur content which many of the older designed engines are designed to run on. The current Euro II is still not good for mechanical injection pumps.
    Sep 2004
    #569
    doc i have pajero gen 3 with 4m41. so it should be safe right?
    #570
    ahh.. i see.. yun pala ang dahilan..thank you very much sir..
    maliban sa seaoil and flying v... are all diesel today euro2?
    #571
    unioil is euro4 sir. and eastern petroleum.
    Apr 2009
    #572
    Mga Sir's ask ko lang po. Is it ok to pour 2 Bottles of 200ml 2T Oil on tank kahit hindi naka Full Tank?? Kasi yung friend ko before siya magpa rehistro nag pour siya ng 2 Bottles of 200ml 2T Oil sa 2004 Isuzu Crosswind XTRM 4JA1 Non-Turbo nya. Then naka babad ang 2T Oil sa tank for 2 days before siya nagpa rehistro. Kinabukasan takbo agad siya sa LTO para magpa rehistro. After that yung Emission Result na nakuha niya is 0.16
    Dec 2007
    #573
    Yes it not considered a ultra high pressure common rail system like engines used overseas. Very few vehicles in the Philippines you cannot use it in.
    #574
    hard to find 2T JASO FC
    ptt 2t is jaso fc
    Apr 2009
    #575
    Last month nagpalit ako ng airfilter, then after a few weeks visible na ang black smoke kapag aarangkada ako.
    Then nabasa ko ang thread na ito, i tried and Put some 2T i bought from petron after going around metro manila, hindi ko na ulit nakita ang black smoke.
    Palagi ko na itong gagamitin.
    salamat sa inyo, sa mga Nag-share ng mga experience nila.
    At kay Sir dvldoc, pilipino po ba kayo?
    My ride is Mitsubishi spacegear 1997, 4d56.
    Dec 2007
    #576
    Black smoke is unburnt fuel, 2T helps your burn that fuel and improves the efficiency of your injection pump. It's a old school diesels best friend.
    Dec 2007
    #577
    Quote Originally Posted by sanik View Post
    It won't harm anything, And yes people use that as a trick to pass emissions. It's not something you want to do on a regular basis.
    Jul 2011
    #578
    ptt 2t is jaso fc
    wala kasi samen PTT kaya eto gamit ko
    API TC and JASO FC rated mura lang PhP25/200mL
    nakita ko lang sa isang fuel station.
    #579
    boss anong fuel station?
    Aug 2009
    #580
    added to bottles of shell 2T with decarbonizer on a full tank of diesel on my 03FM. Question lang po mga sir: is there a need to change my fuel filter? TIA and good am.
Diesel owners that add 2T oil to fuel
