Are there any noticeable effects or benefits between using jaso fb & jaso fc 2SO in diesel cars such as fortuner?
Price difference is night & day
So may be i could assume the effects/performance
Is also night & day?
OK lang still old school engine
Sent from my GT-P5210 using Tsikot Car Forums mobile app
Pag hindi nagluko ang SCV at fuel injectors after 40k-km of use ok lang yung price difference, bonus pa pag inabot ng 60k-km ang odo. ng walang problema. Since ito naman ang pinaka advisable na grade.
As per my computation if 150 pesos ang difference, sa 40k-km odo. around 3k-pesos na mas magastos ang paggamit ng FC grade compare sa FB grade na 2t.
Afaik it is better to have an oil catch can even if you have a working egr.
Or it is a matter of comprehending the statement...
From page 38, same post...
FC was recommended from pharagraph 1.
Due to high zinc content from diesel it is the same if not using FC grade. - From pharagraph 2.
Use of cheapest 2t hence it will be the same as using synthetic oil that contributes ash & sooth.
Thank you sir saberNZ, try ko rin sa trooper ko.
Sent from my GT-S5360 using Tsikot Car Forums mobile app
kung lilinisin mo egr wag ka gagamit ng carb cleaner sisirain nito yung position sensor. linis mo na lang siguro may faulf code sa egr.
LJ78 Prado, 2LTE engine, Petron Diesel max ….. been using petron 2t FB two small bottles per full tank, gumanda takbo, nawala usok and vibration . . .thanks guys . .
Sorry guys... It's a loooong thread so i have to as a question that's probably been asked pages ago.
Just want to double check. Pwede ba to sa bagong Pajero? I know sa earlier pages, sinabi na yung jap crdi's dpa katulad ng korean and euro crdi's na umaabot ng 24k psi yung pressure. Just want to verify kung kasali ba dito yung Pajero engine ko, or even better, if anyone is successfully running 2t in theirs.
4M41 engine ba yan? Alam ko parang may nakagawa na niyan pero sa Strada
Yes, the manual says 4m41. Pareho lang ba yun exactly? I mean, being in 2 different car models, are there differences to consider between their fuel systems, perhaps different turbos if that's even part of the equation? Pasensya, di kase ako ganun ka familiar sa cars and engines, mechanically speaking.
TheGreenThing: sa Aussie4x4 forums marami din gumagamit pero sa nabasa ko, mostly older engines.
Alot of guys in SA4x4 forum are swearing the use of 2SO in diesel.. Meanwhile here in tsikot 99% of the users are happy.. Ano ba talaga dapat?
